Too wide?
Discussion in 'Cosmetic' started by 464925, Apr 24, 2012.
  1. 464925
    In my Mav.
    Maverick 1973-Pure Muscle.
    Hi:
    I put these 14x10 in. with 265/50/r14.
    I looks pretty wide.
    I only wanna know what do yo think?.
    :16suspect
    [​IMG][​IMG]
      File size:
      83.4 KB
      313
      File size:
      65.5 KB
      310
      File size:
      87.7 KB
      312
      File size:
      122 KB
      313
  2. ptpdub
    ptpdub Member
    canada Sk.
    It is ok but it looks like a good way to destroy your nice paint.
  3. 464925
    In my Mav.
    I didn't think on that.
    I love how the wheels looks.
  4. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    To wide, if you could change the off set of those rims and get more tire under the car maybe. Not one to brag my car isnt safe to drive yet:rofl2:
  5. blugene
    I love em. BUT they will get cut when they bounce up into the wheel well. Ask me how I know. I have wide wheels also and used the same size tire before. Ruined them with only a couple hundred miles on them if that.
  6. jm16
    jm16 Joe Marino
    Oak Park, MI
    1975 Comet GT
    Nice looking but stick out too far
  7. blugene
    Nahhh.. They are perfect. The fronts could be a little wider.. And the car needs to sit a little lower.. I run 50's on the front too.. Or at least I did when it was road worthy.:)
  8. 464925
    In my Mav.
    I gonna try some miles. And see what happens. Maybe 14x9" and the same tire could work.
    I like to see pictures of your wheels. :camera:
  9. don graham
    What you could probably use is some more offset. Mine stick out a little bit too on my 71. But it is a race car only so I have fender guards behind to protect the paint. I still get melted rubber on it from the burnouts. So I'm sure you'll be getting a lot of rock chips. :)
  10. maverick75
    Don is right, you have the wrong backspace/offset
    also 10 is too wide imho, you can fit a 275 on a 8" tucked in nicely.
    or a 9" if you run 17s.
  11. 464925
    In my Mav.
    That's the problem. With my 14x7" It had rock chips. I really love how they looks (Love the offset) but maybe cut the wheel to 9" is the correct..
    If I put that tire (265/50) on my 14x7 (Like front), Is it gonna see the same wide? (I want wide):)
    If I put this type of guard, Can I avoid the rock chips?
      File size:
      70.6 KB
      161
      File size:
      90.7 KB
      162
  12. MICHAEL DAVIS
    1973 Ford Maverick
    I see the look your trying to achieve, id stay where your at and lower the car a lil.
  13. 71gold
    thes are my...275x60s on 8"x15" rims...
  14. Craig Selvey
    Yes...those wheels look cool as heck.
    But...no way would I run those wheels on a Maverick. To run that wide of a wheel, the back end HAS to be jacked up. Even with it jacked up, you will eventually hit something or bust an air shock, then the quarter panel will be demolished by crashing down on that too wide of a wheel. You will also slice up your tires with the quarter panel cutting into the side of the tire. some suggest the car now needs to be lowered......NO WAY will that work at all.
    Everything you are trying to do with those wheels on that car is what a lot of us were doing back 30 years ago (in the 1980's). We know the pitfalls and problems. Been there....done that......got the T-Shirt.
  15. Dave B
    Too wide, and too small. I think they look kinda goofy.
