Took a Cowl Apart
Discussion in 'General Maverick/Comet' started by rthomas771, Aug 3, 2014.
  1. rthomas771
    BKelley came over yesterday and we decided to take a cowl apart. We hope to use the bottom section to approach companies for possible reproduction. Even though this cowl was off the car...it was still a bear to separate the two halves.
    Tannersg1 likes this.
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Always a fun project..... Not.....
  3. Dave B
    You should contact Daniel Carpenter, and let him know there would be a market, since they have full access to the Ford tooling already, they wouldn't have to invest in a new die. When I was there, they already have a full warehouse of Ford stuff.
    Craig Selvey and Tannersg1 like this.
  4. mav1970
    I feel your pain - lots and lots of spot welds :yup:
  5. rthomas771
    Went through 4 spot weld cutters then took a drill bit to drill out the rest of the spot welds. I take my hat off to anyone who has done a cowl swap.
  6. mav1970
    I used the 5 dollar 2 sided spot weld cutters from Harbor Frieght - I ate the teeth off of 1 and flipped it around - got finished with half the teeth left but still cut - something from HF that seemed to work really well :thumbs2:
  7. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Bob, a HF spot cutter was the first we tried. Sheared the teeth off on the very first spot weld.
  8. mav1970
    Did you take a center punch to the middle of the spot weld first? If you let the cutter wander around it will eat them up fast
  9. rthomas771
    Yes, we used a center punch before drilling. I couldn't find my $35 cutter that I used when I removed a quarter panel from a '62 Falcon. I bought the same style self-centering cutter but different name brand at half the cost. The first 5 or 6 spot welds were cut with no problem. Cutting #6 and 7 took a little more effort before replacing the bit.
  10. Paul Masson
    1971 Grabber
    I've done it on both a car and on the bench. I used a Spot Weld REMOVER (basically a drill bit) and then filled the holes in using a flattened piece of copper pipe under it as I welded. I looked at buying one of the reproduced Brazilian ones, but the import process scared me (either not getting my parts, or costing too much).
    A good cutting oil helps a lot, too!
