Took the mav to the track for a shake down
Discussion in 'Drag Racing' started by 1974grabber, Sep 26, 2015.
  1. 1974grabber
    1974grabber Member
    buffalo ny
    1974 grabber
    Took the mav to Lancaster speedway for a shake down it was spitting and sputtering like it was losing fuel the fastest time i ran was 925 71mph i know this car is high 7's low 8's .well i took it home took carb off looked it over found on the drivers side of carb there's a screw that limits the throttle from the back that was keeping the back butterflies open so I a justed it and put a 2" spacer it & i bet she'll run now total different animal !!!! :clap:
  2. 1974grabber
    1974grabber Member
    buffalo ny
    1974 grabber
    Here's a pic
  3. 71gold
    you could have shook that down in the driveway...:slap:
    Hotrock likes this.
  4. junrai
    junrai Member
    rancho cordova ca
    but the driveway isnt as fun and neighbors tend to complain if youre doing 71 miles an hour in your driveway :rofl2:
    Comet Fever and 1974grabber like this.
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    1/8th mile?
  6. 1974grabber
    1974grabber Member
    buffalo ny
    1974 grabber
    I have and this is what happens only two passes !!!!! :dance: 8 cop cars later
  7. 1974grabber
    1974grabber Member
    buffalo ny
    1974 grabber
    Yes
  8. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    What did this screw look like?
  9. Krazy Comet
    While that adjustment will cause low speed and/or light throttle issues, really should not make a difference at WOT... Sputtering/popping is more often a ignition related issue, weak spark, bad plugs etc...
    Tell us more about your combo engine, trans, gear etc... I'm guessing it has at least a 3.80 gear and 3K stall as 9.25 is pretty good at only 71 MPH...
  10. 1974grabber
    1974grabber Member
    buffalo ny
    1974 grabber
    You can see where it used to touch the cam now it seems ok and i put the 2in spacer on too there's no stall converter i think the stock gears for the 6 cylinder its a beefed up c4
  11. 71gold
    the bigger problem is the carb is on upsidedown...:slap:
  12. Hotrock
    Munroe Falls, Ohio
    Problem solved!
  13. greasemonkey
    Sedalia,MO
    Without a converter it's gonna be tough to go in the 7's.
  14. Krazy Comet
    Or even more than a mid 8...
    With a 2K stall & 3.00 peg leg rear, my Comet went 9.23@77.7...
    My T-Bird and Marauder both ran 8.3 to 8.4 but were making 83/85 mph...
