Torque box question
Discussion in 'General Maverick/Comet' started by MavMonster, Jul 8, 2004.
  1. MavMonster
    MavMonster Member
    Ames, Iowa
    72 Maverick
    Well I had to rebuild my torque boxes, i used 16 gage steel, it's solid from what i can tell, but this is the first car i have ever restored and teh torque box was one of the first thing I realy welded. But several people have looked at it and are convinved it is great. I gave it the old bash test once it was on there, and it was ok.
    My question is this..
    As of now i have a 200 I6, I havent decided if i want to upgrade my engine or not, but if I do, I am droping a Clevland in. Is there anything else i need to do to my torque box to make it more safe if i am droping a 351 in? I have a friend with 351 stang with rusted torque boxes and he drives it like a mad amn and has no prblems, just wondering what you guys think, thanks.
  2. Craig Selvey
    .....and Better insurance
  3. MavMonster
    MavMonster Member
    Ames, Iowa
    72 Maverick
    but will there be any problems with the torque box?
  4. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    no there shouldn`t be ... thats if you can get a 351 C in there ;)
  5. Old Guy
    Old Guy Member
    Should be ok but I would put in some subframe connecters too. In my own opinion, change the last letter of the engine code from a C to a W. You will find it a little easier to work with.
  6. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    I agree with Old Guy one the subframe connectors, that really help.
  7. MavMonster
    MavMonster Member
    Ames, Iowa
    72 Maverick
    Cool, will do, just incase someday i get the scratch to toss in a big boy hehe, as far as the C ro W I know a few guys that haveing both say the C puts out more power for them, I dunno, what makes the W easier to work with?
    thanks guys
  8. nickriede
    nickriede speed freak
    ottumwa, ia
    73 maverick 2dr, MII front suspension
    the cleveland has biger ports and valves. so it has more power potential, but you better check the width of your shock towers and the width of the valve covers on the cleveland. i first bought a 351M/400 to put in my mav. after i got the engine home i found i needed either 4 inchs more clearence or the valve covers were 4 inches wider than the shock towers. so be carful what you spend you money on. i wasted $150. id go no biger than the windsor but even with the taller deck height of the windsor it will be a tight fit.
  9. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You would definitely need to modify or eliminate the shock towers in order to drop in a 351 Cleveland, a 351 Windsor is a tight fit but it will fit.
    With the modern cylinder head offerings available for the Windsors power should not be an issue.
  10. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    You can put a Cleveland in with no modifications. I have seen it done. Not sure what headers you will need but they are out there. Call Tubular Automotive. I believe a M and 400 both have taller blocks and possibly wider, I cant remember...dont use them. Good luck its still a lot of work!
  11. MavMonster
    MavMonster Member
    Ames, Iowa
    72 Maverick
    hey thanks a ton guys for the good info. I havent shopped areound for theses engines yet, so i was clueless. Thanks again
    On a side note i dont mind haveing to do modifications, i want to learn how to do everything possible with this car, I'll just have to see what options i have when the time comes.
    thanks again
  12. DarthMaverick
    DarthMaverick The Yang of Mavericks
    Bakersfield
    1976 2 door Maverick
    I have never heard the term torque box...is that the chassis?
    Just wondering...
  13. maverick1970
    Missouri
    The Torque Boxes would be the rear supsension attachment points
  14. Craig Selvey
    The torque boxes are located directly behind the front wheels.
  15. VometComet
    VometComet Member
    Wickenburg, AZ
    74 Merc Comet 302
    What are they torqued to? I'd guess at least 80lbs...yuk yuk yuk
