Trans Cooler
Discussion in 'Technical' started by demo913, Sep 8, 2010.
  1. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
  2. PaulS
    Looks like a good one!
    Hook it into the passenger side cooler line - that is the return on a C4 unless it has been modded before.
  3. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
  4. PaulS
    Almost all coolers have 3/8" fittings, The C4 has 5/16" fittings but as long as you set a "bump" in the line with a flare tool you can tighten the hose down and it will not leak or come loose.
  5. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    OK. Thanks PaulS.
  6. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
  7. mojo
    I use the BM Super Cooler #130-70268 frm Jeg's less than $50.00, rated 13000 gvw.
  8. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    The B&M stacked plate design coolers are much more efficient than the tube & fin design of that Hayden. In fact, you can run a B&M cooler as a stand-alone setup and the transmission will be cooler than running the radiator cooler and a tube & fin cooler. This also allows the engine to run cooler since the radiator is only working on the engine and not on the engine and transmission.
  9. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
  10. mojo
  11. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Anyone concerned about too much cooling and running the trans below operating temp? If/when I get a higher stall converter I'll consider a cooler but wonder if it would do more harm than good. 99% of my driving will be around town with a very occasional romp. So, what's worse, over-cooling it 99% of the time or over-heating it 1% of the time?
  12. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
  13. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Thats a great question jsarnold. I am curious for someone to answer that for us.
  14. mojo
    That is a gud question JS, but me not having a gauge on my trans I am in the possible over-cooling category. I don't know what my converter stall is cuz I bought the car w/o that info. The car had been mildy modified and I don't even know what engine I have - all I know is it runs and shifts great.
    I have alway heard that heat is the enemy of trans survival so I have aired on the side of 99% v 1%. Over-cooling might be an issue if I used the car in winter months but that's not the case, so, I guess it depends on variable circumstances - who will be in what category.
  15. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    Nope.
    :thumbs2:
