Transmission Lines 72 on a 73 5.0?
Discussion in 'Transmissions' started by CentralValleyComet, Jun 26, 2012.
  1. CentralValleyComet
    CentralValleyComet Member
    West Coast
    73' Comet 302 4-Door
    Does anyone know if the 72 lines on a comet will work on a 73? It's a 4-door if that helps.
    All I can find close is 1972 lines for 60$. PreBent.
    I am thinking this should work but I am a novice and I just like to work on cars so help me out fellas.
    I really dont want to have to put a rubber heat tube and clamp it off an both ends.. I would much rather put in close too or same orig.
    I only need one replaced so let me know what you all think.
    you guys always help me out.. Good looken out:tiphat:
  2. Craig Selvey
    Yes...they will work.
  3. CentralValleyComet
    West Coast
    ok well im going to order them/ will I still need a bending tool? All I have is a Line Cutter.
    thanks, this makes it easier on me
  4. Craig Selvey
    The may require some "tweaking"...but nothing that can't be handled by hand.
  5. maverick@heart
    maverick@heart Member
    Hendersonville TN
    1975 American Maverick, 1976 Mexican Maverick, 1973 Maverick
    I did it and only required patience to get them in place without kinking them. No other tools needed than wrenches.
  6. CentralValleyComet
    West Coast
    72 on a 74 cooler lines
    i said 73 i meant 74. they fit but i cant get the piece to screw in opposite the radiator.
    it might be a little too big, no idea what to do next. i feel like cutting the old line and using heat res rubber.
    so again i think the screw is too big.
    will 72 cooler lines work on a 74?
  7. maverick@heart
    Hendersonville TN
    They can sell you the hardware need it to conect them at the autoparts. I believe 72 would fit a 74.
  8. CentralValleyComet
    West Coast
    so the end going into the transmission should crew in, it seems a tad to big but ill try again.
    I have the lines just cant get it to screw in.
  9. simple man
    simple man Member
    Bunnell,Florida
    There were different size fittings ( the ones in the radiator ). Take out the one you have and take it to the auto parts store and get the larger one. The end that screws into the radiator stays the same size. The end the metal line connects to has two different sizes! :)
  10. CentralValleyComet
    West Coast
    i dont get what your saying?
    i cant get the line to screw into the transmission. It might need new threading. can I just take off that fitting. the part under the car sticking out of transmission. No idea what that is called
  11. Craig Selvey
    Does your transmission have 90 degree fittings coming out that these new lines screw into?
