Transmission swap
Discussion in 'Transmissions' started by Campmaverick, May 13, 2022.
  1. Campmaverick
    Campmaverick Member
    Reedley ca
    1972 Maverick grabber
    Transmission swap Hey I have a C-4 transmission behind a 200 6 cylinder Can I take another C4 from V-8 use the bell housing put that on my transmission form my six-cylinder Will that work with no problems and would I be able to use my torque converter and fly wheel thanks
  2. Krazy Comet
    You'll need to use the 6cyl converter & bell. The 170/200 six has has ring gear welded to converter.
  3. Campmaverick
    Campmaverick Member
    Reedley ca
    So the bell housing is interchangeable you’re saying that I will need to use my torque converter and fly wheel because it’s welded together will it work behind the 302
  4. Campmaverick
    Campmaverick Member
    Reedley ca
    Oh I read it wrong so the bell housing will work and my converter from the six cylinder will work I have to buy a new flex plate
  5. Krazy Comet
    Are you swapping 6cyl transmission to 302 or the v8 trans to 6cyl?
    Bell housings swap, 170/200 smaller than V8 or 250 six. Converters must match bell housing. There is no separate flywheel fo the small 6, welded to converter.
