Transmission will not lock in PARK unless moving.
Discussion in 'Technical' started by scooper77515, Nov 20, 2011.
  1. scooper77515
    We have been adjusting the linkage at the transmission and it now shifts through all the gears, but when putting it into PARK, it may or may not lock. It WILL lock when we push up on the shifter and rock the car, but I am afraid it will fall out randomly.
    Any suggestions?
    Not my car, by the way. Working on Phreeq's 71 with column shift C4
  2. darren
    Any play in the linkage?? Hole the shifter arm at the trans firm and move the column shift. How much play?
  3. scooper77515
    none. Everything is tight.
  4. JAYSMAV
    JAYSMAV Member
    Ohio
    '73 Comet 302 LDO auto, '70 Maverick I6
    What trans do you have?
  5. JAYSMAV
    JAYSMAV Member
    Ohio
    If its the c4, I've had this happen. It was the shift linkage out of adjustment. I bought a ford trans book by haynes, and followed the steps for the rod linkage adjustment. It worked. Never had a problem with it not locking in park again.
  6. scooper77515
    DOH!!! I have that book. Didn't even think of looking at it!
    Phreeq, swing back by this week and we will do it right, it you don't see it hooking better.
  7. Craig Selvey
    Make sure the plastic bushings are in good shape. I have seen those being worn out, and even totally missing, and cars having this problem. On the cars with none....a previous owner just drilled a hole in the linkage and put in a cotter pin. NOT the way to fix a missing bushing. :D
  8. scooper77515
    Well, just read the book, and pretty much what I did, except I did it in 1, and not in D.
    When he comes back over, we will do it correctly and see if it fixes his problem.
  9. phreeq
    phreeq Member
    Atascocita, TX
    Finally getting a chance to get on here.
    Thanks for all of the tips, guys. I may either swing by your place or have you swing by mine either tomorrow or Tuesday night to look at it.
  10. scooper77515
    I have a full day of work on monday and half day tuesday, free the rest of the week.
    The "8 lbs pressure downwards" may be our problem.
    I will need you to get in there and hold the shifter down a bit while I crank down on the bolt...
  11. scooper77515
    Sorry, you don't know what I am talking about...I didn't list out the instructions here.
    The book says to move the shifter tightly toward D keeping 8 pounds of downward force on the shifter, meanwhile, I move the transmission to D and crank down on the bolt.
    That is supposed to line it all up.
  12. scooper77515
    Previously, I just put in in 1, put the tranny in 1, and cranked down the bolt. It ran through all the gears correctly, and went into park, but only half the time.
