Tremec 6-speed
Discussion in 'Technical' started by Hawkco, Jan 19, 2005.
  1. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    I have an opportunity to pick up a Tremec 6-speed that was factory installed in a C-5 Corvette. Anybody have any clue whether or not it can be modified to bolt up to bellhousing for the 351W? What may be some of the peculiarities of this particular transmission?:confused:
  2. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Okay. Anybody know somebody I can ask these questions?:huh:
  3. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    might want to check out advanceadapters.com I think, they had all sorts of stuff for 4x4's and such
  4. Maverick Man
    California
    wow that would be really cool? when you figure it out let me know :D
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The C5 Vette uses the T56, but the tranny is rear mounted...
    (LS1 engine, clutch, torque tube, tranny, then rear diff)
    I don't know how that will affect it's ability to be adapted.
    Having owned an LS1 Camaro with a T56, I do know that the LS1 version of the T56 does not lend itself to swapping onto other engines.
    I know for a fact that an LS1 T56 cannot be adapted to a small block Chevy...
    Stands to reason that the tranny needed for an SBF would be the SBC version. Therefore if the SBC and LS1 trannys are incompatible, that it wouldn't swap with the SBF.
    The standard T56 is fairly weak. The syncros are cardboard... literally.
    The input shaft is weak.
    One of the 2 internal shift rods bends easily.
    The way around these weak spots is to either install the Viper spec parts or use a Viper spec tranny.
    The Viper:
    Syncros are kevlar.
    Input shaft is hardened.
    The shift rods are steel.
    Good luck
    Dave
    Edit:
    The T56 is a Borg-Warner design. It has been around a long time and B-W wanted out... Tremec bought the rights to the design in late 98. The better T56s are said to be the ones marked "Borg-Warner". The Tremecs are said to be even weaker... at least on the LS1 boards I am a member of.
  6. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    6 speed
    i used to adapt top loader 4 speeds from a ford to a sbc or a bbc very easily. so if the bolt patern is the same then it will probably adapt. ck it out:huh:
  7. tim keck
    sharps chapel,Tn
    Another thing is they use an electric speedo.They make a viper spec t56 to bolt to smallblock fords,but the gm version is not very adaptable,so I've read.
  8. ratio411
    ratio411 Member
    Pensacola
    That was my point exactly...
    He is looking at an LS1 tranny, not an SBC/BBC tranny.
    The LS1 tranny is a completely different animal and will not adapt to the SBC/BBC, therefore I doubt it will adapt to the SBF.
    I forgot about the computer controlled speedo...
    These cars do not use the tranny at all for the speedo. They use the ABS sensors for speed readings. You would have to hook an aftermarket speed sensor to a wheel or something, unless you got a swap specific tranny.
    Dave
  9. Thack
    Thack vision advicator
    Moreno Valley Ca
    In my opinoin the six speed has no advantage over the 5 speeds availible, except for cool value. If you compare ratio's for each gear the six speed has an extra gear between 4 and 5 on the 5 speed. This would be great if the 6 gear was significantly taller than the 5 speed trans but it's not. Or have close ratio 5 gears with an overdrive. Then you could set up for excelleration and freeway cruise. I just can't except the cost for coolness, unless you get the trans cheap or free.
    my 2 sence :D
  10. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    BINGO!!!!!
    I was going to get the deal of the century, but after reading all this good info, I probably will not fool with it.
    Thanks for the info, guys!!!(y)
  11. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    Terry, I suppose if you wanted to go nuts, you could put corvette suspension in all 4 corners, and then use a vette drivetrain to use the trans :p
    Shaun
  12. Earl Branham
    Lugoff, SC
    Bite your tongue!!!!!!!:slap: :eek:
  13. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    hehehehehehehehehe:D
    Thought that would get ya'll going!
  14. Earl Branham
    Lugoff, SC
    That would be the fastest mistake you ever made!
  15. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Well...it would handle better, but I only want to do that slightly more than I want to cut off my legs.:49:
