Trim Tag Location ?
Discussion in 'General Maverick/Comet' started by ChiefRocka, Jul 13, 2018.
  1. ChiefRocka
    ChiefRocka Father/Son 69.5 Build
    Hollister, Ca
    69.5 Maverick
    I have a 69.5 …
    Curious as to where the trim tag is … or supposed to be ?
    Thanks
  2. Acornridgeman
    Wisconsin
    The early cars had a metal tag, just like other Fords of the later 60's, attached to the drivers door by the latch mechanism. Later in the 1st year it was the foil sticker attached to the body below the drivers side striker plate.
  3. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    Ahhh, so it's on the actual door ?
    No wonder I didn't find it...I will look again.
    Thanks
  4. Acornridgeman
    Wisconsin
    If your car has the original door and it is missing, you will see the 2 rivet holes where it used to be. If the door was swapped out the tag was probably tossed with the old door. Marti can make new ones if you want one.
  5. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    Thanks again !
