Trouble with 88300 headers and power steering
Discussion in 'Technical' started by dougsharp, May 1, 2017.
  1. dougsharp
    dougsharp Member
    Lake Waukomis MO
    1973 Maverick
    Just installed my new 88300 Heddman long tubes on my 1973 Maverick , 347 , 5 speed , power steering. Once installed , my power steering slave cylinder will not clear the tubes, even with the recommended drop down bracket. I would need to extend the drop down bracket an additional 2 inches to clear the bottom tubes(which I suspect would cause a steering geometry problem). Anyone else have this issue?
  2. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    It seems like these headers are not gigged correctey.
  3. baddad457
    Time to convert to manual steering.....................
  4. dougsharp
    dougsharp Member
    Lake Waukomis MO
    1973 Maverick
    You read my mind. In process of changing the water pump to standard rotation , removed the pump and bracket , and ordered the power steering adapter from rare parts today! Should gain 10-12 hp and eliminate a little weight.
  5. Krazy Comet
    If removing P/S gave a 10 HP gain, probably 90% would can it...
