trunk springs/hinge
Discussion in 'Cosmetic' started by Hottrod1991, Apr 19, 2010.
  1. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    I'm having trouble trying to get the spring on the bar for the trunklid/hing
    my passenger side is tight and the driveside is loose
    how does the hanging piece go back on?( the pic is of the passengerside)
  2. brainsboy
    brainsboy Member
    Tampa
    The passanger side is the only side that has the spring in it. The drivers side is just a hinge
  3. mercgt73
    mercgt73 Member
    yep, and the passenger side hinge gets "loaded" by the torsion spring. it (driver's side end) goes into 1 of the slots on the driver's side hinge support.
  4. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    but wher does the hanging part go??? cant figure out how it go's back on
  5. rthomas771
    Here's a pic of my trunk spring.
  6. mercgt73
    mercgt73 Member
    I think he needs a pic of the assembled passenger side...
  7. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    yea i need the other side of it,I need 2 know wher the hanging peace go's on.
  8. blugene
    Does this help?
  9. blugene
    Looks like you need to remove the spring and put it behind the hinge.
  10. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    yea that should do, hopefully i can get it on lol thanks for the pic
  11. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    ok well.....didnt get it on yet.:( want to ask if both of the bars for the trunk are possed to be the same lenth.?? Cause the right one with the spring dont go up all the way as the driver side does. Is thier any way to make the bare come out more?? If so how do i do it??
  12. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    bump!!!!!!!!!!
  13. blugene
    It looks like you need to remove the spring and raise the lift arm and put the spring in behind it.
  14. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    To get the torsion bar on I used a 3/8" (IIRC) deep socket on a long extension. Slip the end of the torsion bar into the socket and you'll have plenty of leverage to load it and put it in whichever slot you want.
  15. blugene
    Take the spring off and move the pass side hinge arm up and put the spring back in with the arm in the up position.
