Tuning
Discussion in 'Technical' started by TrotMaverick, Jul 15, 2012.
  1. TrotMaverick
    TrotMaverick Tyler Trotter
    Gaston, Oregon
    1972 Ford Maverick Grabber, 2016 Chevy Sonic
    What is the best way to get my carb/timing all tuned and running good? I've messed with it several times and it's good for a little bit but it always starts to act up after a little while. I'm not using any measurements or anything of the sort just playing by ear. Anyone have tips or is it just something I'll have to continue to tweak till I get what I want?
    And just extra info, I have about a quarter pedal of acceleration. Any more pedal I put into it my car just bogs down and acts like its not getting a steady fuel flow. Possibly just a bad mixture...?
  2. bmcdaniel
    bmcdaniel Senile Member
    What engine and what carb?
  3. TrotMaverick
    Gaston, Oregon
    Running a stock 200 I6. Replaced the carb (1bbl) about 3 months ago. What should I upgrade to? Never against an upgrade. :D
  4. cody674
    cody674 Member
    1972 Ford Maverick
  5. baddad457
    X2 on this. (y)
  6. Jory
    Jory Member
    Greenville, Texas
    1971 Ford Maverick 4-door
    What kind of acting up is it doing?
    A few of the best investments I've made so far for tuning/reliability/consistency are:
    1) Pertronix electronic ignition (getting rid of points was AWESOME! No more gap/dwell setting!)
    2) Timing light (works well unless your distributor has been removed and put back in a few teeth off from where it was).
    3) Vacuum gauge (tuned for max vacuum on idle, detects vac leaks, etc.)
    4) Volt meter (lets me see if I'm getting power, how much voltage/resistance, check ground wiring, etc.)
  7. TrotMaverick
    Gaston, Oregon
    I looked at pertronix a little bit. It just bogs down after a bit of pedal. And it starts/runs great the first time I start it. But if I turn it off. Wait a few mins and try to turn it on again it runs really poor and dies multiple times if stopped and in gear
  8. MSmithPDX
    MSmithPDX Member
    Portland, OR
    What petronix did you install?
    I'm happy to give advice on getting it running right.
    Or am I reading that post wrong.
  9. baddad457
    You're reading the post wrong, he's still running points. A good place to start would be a full tune up and at the same time, replacing the points with electronic. This should eliminate the ignition as the source of his problem.
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    probably not a bad idea to check that carb out too.
    A "quarter pedal of throttle until it bogs" would need to be a seriously bad timing curve or very poor spark to act like that. Much more likely to be fuel related, IMO.
  11. TrotMaverick
    Gaston, Oregon
    Any advice on which pertronix unit I should go with?
  12. mav_man_71
    mav_man_71 Member
    Brighton,Ontario,Canada
    I've been using the orignal pertronix for about 10 years now in my 71 grabber and it works great.:thumbs2:
  13. TrotMaverick
    Gaston, Oregon
    The ignitor? I was looking at the ignitor 2, anyone have bad experiences there?
