turn signal switch removal
Discussion in 'Technical' started by Johng1970, Aug 3, 2015.
  1. Johng1970
    Johng1970 Member
    Freeport, PA
    Can anyone tell me how to take the turn signal switch out of the steering column? I have to get the ignition switch out to replace it.
  2. 71gold
    didn't know the ignition switch was in the steering column...:huh:
  3. Krazy Comet
    The ign sw is on top of the column directly under speedo... If you mean ign LOCK, isn't necessary to remove the signal sw, just the steering wheel... With ign on, there is a small button that must be pressed to release it.... All Fords from '70 up are basically same, should be plenty of picts on net...
