Please Help!!!!! The left hand turn signal insturment panel light does not work. It clicks and the outside blinker works. Just the insturment panel light does not illuminate. Have changed the flasher and insturment panel lights, but it still will not illuminate. Could it be the turn signal control harness?
mine does the same thing havent replaced the bulbs ye thou but you dont really need it ... just put a tach on the steering column and cover it up hahaha
sounds like the harness is working ok,if it's activating the outside lights.instead of swapping just the lights,swap out the whole fixture(the pc.that holds the bulb,with the 2 gold contacts).i've seen before,where the contacts get dirty,also clean the circuit board,for that light.next step,i would take a test light,to some wiring,and the board.
I completely removed the insturment panel, cleaned and repainted and changed all the lights. It wasn't working before I did this and still is not working.
