Turn signals, radio, volt guage dead need suggestions?
Discussion in 'Technical' started by marty robbins, Mar 21, 2004.
  1. marty robbins
    marty robbins Member
    Olympia, Washington
    1975 Maverick Grabber
    O.k. have a problem that keeps popping up, last year our mechanic replaced a couple of turn signal switches (bulb sockets), and the fuse. The same fuse has kicked out twice, a couple of weeks ago, my friend and I put in a set of auto meter guages, and this week the car got her new clutch, every thing was fine until today I took the E-brake off and the volt guage went to 10 and did'nt move no turn signals and no radio, any suggestions on where to look for this problem as you guy's know replacing the fuses is not fun with the clutch in the way. P.S everything else is working, brake lights headlights. Thanks Marty:mad: :mad:
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Marty, first thing is to make sure the fuse that is blowing is the right amp rating. The deal with your park brake being released and your volt gauge reading is a sign that maybe a wire was interferring with the park brake. You stated you installed some gauges, I would trace all the wiring in that area to make sure that none of it has become bare, frayed, or broken. Just another safety tip, remove your negative battery terminal while doing any of this kind of work.
    Dan
  3. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    The never ending story
    you'll find the E pedal is near the fuse box and the plugin for the firewall connection. Probably some old wires rubbing on the firewall in that area.
