Turnsignal works, hazard dont.. solved
Discussion in 'Technical' started by the muss, Jul 14, 2016.
  1. the muss
    the muss Member
    norway
    1970 maverick with 351 w
    So i've been browsing the forum but Cant find anything That helps me. So this is how far i have got. The turn signal works when the hazard switch is OUT. They dont work when i push the hazard switch in. In my head the hazard light should Come on when the switch is in. So i changed the relay That Was not "clicking", i measured That There is 12 volts when the switch is in. And 0 when it is OUT. But the hazard Wil not Come on. What Can be wrong. Everything seems to do what they should but still no hazard lights. The relay i switch is round and has 2 contact points. 12 volt wire is Yellow With red stripe. The " Other side" has 2 wires. One is red With White stripe. The Other one is dark blue With white stripe. Can anyone help?
  2. Krazy Comet
    R & L signal operate with hazard sw IN, hazards operate with it pulled OUT...
    I believe the hazard flasher is different in operation from the std, not sure a R-L flasher will work in it's place...
  3. the muss
    the muss Member
    norway
    Hehe ok i figured it out. Now With the switch out the turn signals work. With the switch in the hazard light work. I soldered on av litle wire inside the switch so both work. Only problem is That the ignition switch has to be turned on With the hazard lights on. But i Hope i newer need them. And when i show the Car to get the lisence plate they work so i am happy
