umm....> Rear discs??
Discussion in 'Parts Interchange' started by starsky74, Apr 21, 2008.
  1. starsky74
    starsky74 Technician
    Hackberry Louisiana
    NO not Discus! what should i get the rear discs off of at the pull-a-part to fit my 73 mav?? anyone done this without bookoo's-O-cash?
  2. Earl Branham
    Lugoff, SC
    Got mine from '96 Explorer.
  3. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Got mine from a 94 Lincoln Town Car.
  4. starsky74
    Hackberry Louisiana
    how much modding was involved?
  5. 71gold
  6. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Minimal modding on my part. I had already planned on lowering my car 2" so I didn't have to elongate the bolt holes as described in the writeup. All I had to do was grind the rear of the bracket flat (remove some casting) and bolt them up. It was virtually a bolt on deal. It took more time installing and re-flaring brake lines than it did installing the components. Franks writeup (in the link he posted) was the guide I used to do my swap. Get the components, print out the writeup, get on the floor in the garage with some tools and a grinder, and in about an hour you'll be done(with the install portion).
    (y)
  7. starsky74
    Hackberry Louisiana
  8. baddad457
    I see no one's even thought about the 90's Crown Vic discs. These are supposedly a near bolt on swap for the 8" rears.
  9. 71gold
    the CVs i looked at have 1 cali. mounted front of the rotor the other to the back...my Linc. are both to the rear.:yup:
    ...Frank...:Handshake
  10. starsky74
    Hackberry Louisiana
    thats odd?
  11. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    hmmm, I gotta look at my crown vic tomorrow,, I used Explorer stuff on mine.
    Dan
  12. yerg
    yerg Member
    okolahoma
    also have a 73 mav and am planning on doing the conversion tomorrow if all the parts can be found...front conversion is already done..does anyone have picts of the difference of the lincoln vs the explorer? does the explorer have to be the 8" or will the 8.8 alsdo work? dont know but am just trying to find other year vehicles that will also work in case the explorer parts cant be found...thanks matt
  13. yerg
    yerg Member
    okolahoma
    dan did you use an article from this forum and what year of explorer did you use as a doner?
  14. sierra grabber
    sierra grabber Certifiable
    northern nevada
  15. yerg
    yerg Member
    okolahoma
    LOVE the stallion and the paint Dan...exelent job done on this ride...top of the line..
