Under Carriage
Discussion in 'General Maverick/Comet' started by goldnrod, Sep 28, 2015.
  1. goldnrod
    goldnrod Member
    Fredericton, NB. Canada
    72 comet gt
    With colder weather just around the corner, I'll be sanding my under carriage again. The areas already started have been POR 15 but I would like to top coat that with the correct factory finish. Should my Dearborn 72 Comet be red primer, body colour or dark slop Ford primer. Also should the trunk splatter paint be light or dark grey.
    Thanks
  2. rthomas771
    It think that GM did the splatter paint...not Ford. Here are pics of a St. Thomas '70 Maverick.
  3. mav1970
    So that is what a St Thomas 1970 is "supposed" to look like :biglaugh:
  4. goldnrod
    goldnrod Member
    72 comet gt
    Thanks, it appears to be a flat or semi black with body colour over spray, I 'll follow this treatment.
    Just a side note I thought the mustangs were red oxide.
  5. Krazy Comet
    Ask frankf, he has a low milage(like 15K) '72 Dearborn Comet he's doing a resto mod...
  6. goldnrod
    goldnrod Member
    72 comet gt
    rthomas: Thanks for the pictures of that original car..nice. Hard to tell with the photos is it flat black ?
  7. Paul Masson
    1971 Grabber
    I'm not much help with the Dearborn cars, but my Kansas car has more body colour on the undercarriage than primer. The floor pans and undercarriage is covered in 45 year old undercoating on mine, but the area above my gas tank was yellow. I can see VERY faint evidence of red primer on the inside of my quarter panels.
  8. Paul Masson
    1971 Grabber
    Mike:
    I believe the car Jeff is referencing is the same low-mileage 70 that I have been refering to for detailing on my own. It's kind of misleading, because the body colour of that car is actually pretty darned close to red oxide primer...
  9. goldnrod
    goldnrod Member
    72 comet gt
    There's no way with that much yellow under the tank that it could be over spray. Also sent PM to franktf hope he can add to the conversation.
    Paul Masson likes this.
  10. Mavman72
    my KC Built mav was also body color underneath like Pauls'...It is now all black...
  11. goldnrod
    goldnrod Member
    72 comet gt
    Well that's two original body colour and one original black.....Hope to hear from others.
    There is very little original cars up here to be found.
  12. Krazy Comet
    goldnrod likes this.
  13. goldnrod
    goldnrod Member
    72 comet gt
    That's 3 body colour and one black
  14. Krazy Comet
    My '72 is a KC build and now painted black, but under the upper shock mounts is the original bronze body color...
  15. Dave B
    Here's my 73 Grabber, California car. Under all the grime, it was white, and the tunnel was black. Kansas built, early 73.
    Here is my second 73, which was brown, with white stripes, after I cleaned the white off the floor, you can see the red oxide was over sprayed to the edges or the frame rails, and the rest was black, most was covered with white.
