Under Hood Paint Color Seperation
Discussion in 'General Maverick/Comet' started by orig72 grabber, Apr 2, 2017.
  1. orig72 grabber
    orig72 grabber Member
    Innisfil, Ontario
    72 Maverick Grabber, 72 Comet GT, 74 Comet GT
    I'm in the process of prepping my Comet GT for paint, the car is red and the engine bay is black, where is the factory parting line for the 2 colors. The cowl is currently red including the lip that the tower braces are bolted to, there is some peeling of the red paint along the lip with black visible underneath what is correct. Also the hood hinges are painted red, is that correct or were they black. Some pictures of an original car would be nice to look at.
  2. Krazy Comet
  3. orig72 grabber
    Innisfil, Ontario
    I know some were body color and some were black, my grabber is body color my Comet GT is black, I need to know where the body color ends and the black starts on the cowl.
  4. goldnrod
    goldnrod Member
    Fredericton, NB. Canada
    72 comet gt
    I think it was along where the cowl was put together then caulked ?. Hard to find original cars where I live so hopefully someone else can confirm this.
    Hood hinges were bare metal phosphate coated and protected with oil. You can duplicate this finish with a paint or Google the process but last time I checked
    Supplier of the chemicals could not ship to Canada.
  5. Krazy Comet
    Well I thought was maybe someone would look at the pictures in the links I posted...
    Frank's Comet sans engine, hinges are rusty no doubt not painted...
  6. Craig Selvey
    On some years the hood hinges were painted body color if the engine bay was body color, but I would bet your 1972 Comet GT would be bare metal on hood hinges.
  7. Paul Masson
    1971 Grabber
    IIRC, your 72 Comet GT is a Dearborn-built car. Those had black engine bays, as best as I can tell. Here is a page from the Factory Assembly Manual (not the shop manual).
  8. goldnrod
    goldnrod Member
    72 comet gt
    Looks like the Maritimer's are awake, good morning Paul.
    The shaded area does that indicate black paint ? I can't read the notes A, 1, and 2.
    Paul Masson likes this.
  9. Paul Masson
    1971 Grabber
    Wide-eyed and bushy-tailed Mike! Good to see you on here! It's been a while since I talked to you...
    Yes, the shaded area is black. The interface between the two colours goes up across the cowl-to-fender bracket almost in the middle. If you line-up the masking tape so the black is aligned with the fireweall.
  10. Paul Masson
    1971 Grabber
    This is my original, untouched engine bay, as-found with 19,000 miles on it when I first got the car.
    jasonwthompson and 71Mavrk like this.
  11. orig72 grabber
    Innisfil, Ontario
    It looks like they spray the engine bay black first without taping off the area, then taping off the body and spraying body color. This would explain the red peeling showing black underneath, the car was not originally black.
  12. Paul Masson
    1971 Grabber
    Mine was opposite to that. The yellow was peeking out from under the black on the top of the fender aprons. There was also evidence where the heater box washers were that the yellow was painted before the black, AND with the heater box installed...
    You can also see how the black faded-out towards the top of the firewall. The lip of the firewall/lower and upper cowl was all yellow on my car.
  13. goldnrod
    goldnrod Member
    72 comet gt
    I thought the black terminated at the caulking line where the cowl pieces are joined....Looking at the photos I'm wrong again.
    Clearly the yellow paint is over the caulking.
  14. Krazy Comet
    Different assembly plants no doubt had some variation in their methods, seen it the lower cowl(area that meets firewall) painting of '69 Fairlane/Torinos... It was body color on cars from Atlanta, KC & Lorain, while San Jose painted that area black... Same as underhood... Key here was San Jose also built Mustangs, those all had this area black... Guess what they built in Dearborn? Meaning their method was going to be as close to Mustang's as possible...
  15. baller10pg
    baller10pg Member
    Fort Mill, SC
    1973 Maverick
    Aye man can you send anymore pictures of that?
