Upper ball joint (permanently affixed)
Discussion in 'Technical' started by mark_b, Dec 17, 2002.
  1. mark_b
    mark_b Member
    western PA.
    73 all original 302 2d red blk int. 72,302.2dr. green and 71 200ci. 2d green
    Ok, I did everything I could to seperate the upper ball joint. I broke one Ball joint separator and bent the other. I used a huge 6# hammer and no luck! Any suggestions?
  2. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    This is what I do and never fails.
    Use a large hammer on the end if the spindle mounting point where the joint taper comes through. Hit it hard a half dozen times. You are trying to distort the metal just enough to let loose of the ball joint stud. This does no damage. Thats it.
  3. Craig Selvey
    I have a suggestion....try a bigger hammer.
    Seriously, it should seperate. Sometimes they are seperated, but because of the pressure from the lower A-Arm...it holds it up there and it doesn't look seperated.
  4. 76 Mav
    76 Mav Reformed Camaro junkie
    Cobb County Ga.
    76 Mav , 70 Galaxie ,04 F350,03 Mustang,03 F150
    I know when doing King Pins on an F-100 you need to apply heat ... try warming it up a little at a time ...
  5. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    Ken has the right idea. Hit the spindle on the side as hard as you can with the biggest hammer you can get your hand on :D
  6. mavman
    mavman Member
    Arkansas
    I also agree with Ken. Hit the end of the spindle pretty hard, and around the outsides of it as well. You'll never use a separator again after you figure out how well it works.
  7. mark_b
    mark_b Member
    western PA.
    Cool, thanks...I will do that!
