upper control arms
Discussion in 'Technical' started by 71nogo, Aug 12, 2010.
  1. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    I have been shopping around for control arms for my 71. seems like most are built in china. some with out the ball joint some with. anyone have a line on something better? a few bucks extra is not as important as doing it right the first time.
  2. Moneymaker 1
    Panama City Florida
  3. rthomas771
    Good quality UCA cost around $80-$100. I wouldn't spend my time on rebuilding the originals. Getting the shaft centered and torque without collapsing/bending the arm is job…if the threads don’t strip getting the shaft out or back in place.
  4. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    do you think i need to replace the shaft? or just do the bushing kit?:hmmm:
  5. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I agree but in some cases the aftermarket arms are more flimsy than the factory ones!!!! sad but true.....
  6. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    Every car I've done needs the shaft, never personaly had any problem rebuilding them. Perhaps that's due to my excellent choices of pristine rust-buckets, or just dumb luck
  7. mojo
    What is UCA?
  8. Mavman72
    U...Upper
    C...Control
    A...Arm
  9. MikeG747
    MikeG747 Member
    Arkansas
  10. blugene
    Third...:)
  11. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    ok, im going to rebuild my uca instead of buying the over seas one's. but im still not sure if i need to replace the shaft or just have new bushings pushed in. moog parts- got it. just need to do it right the first time.
  12. Joe Dirt
    i upgraded to the granada style bushings (rubber)
  13. rickm
    rickm Member
    Owosso Mi
    What are Granada style bushings ? The differents from Maverick ? Where would you get Granada bushings ?
  14. Joe Dirt
    Moog Problem solver bushings and shaft. Part # K8233
    This kit replaces the metal on metal shaft/bushing with rubber bushings similar to those used on Chevy uper a-arms. No greasing required, ever. A second advantage is that the width of the shaft/bushing is about 1/2" narrower per side. This will allow you to do the Shelby 1" drop of the a-arms without worrying about interference from the shock tower sides.
  15. blugene
    The kit comes with the shaft and two bushing ends that screw into the UCA and screws on to the shaft at the same time. I recall explaining this to you before. The factory style bushings do NOT get pushed or pressed into the UCA. It also has to be centered as it all goes together or it will bind.
