upper crontrol arm rebuild.
Discussion in 'Technical' started by FoMoCo73, Apr 28, 2005.
  1. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    '73 302 parts car 1969 1/2 351w/tko-500 in progress
    anyone ever rebuild their upper a arm?
    i have a question about the part that actually bolts to the shock tower.
    once the "grease caps" on each end are tight to the arm...obviously the "center rod" (or whatever its called) is supposed to spin as the suspension moves up and down.
    i notice that you can spin this thing...and it will move it forward and backwards....where do i want it to be?
    do i just center it out?
    will this affect caster?
    i heard that some cars have caster adjustment shims...mine didnt have any.
    any info is appreciated
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I rebuilt my upper arms. The end caps are screw into the upper arm. The shaft is center. From the shop manual it says to measure the distance from the center of the bolt hole to the arm. Do this on both sides until the distance is equal. I hope this helps.
    There is no shims and it will not affect the caster.
  3. bmcdaniel
    Yeah, and torque the end caps to 30 ft lbs, if I remember right. I filled the caps part way with grease before I put them on. some came out the zerk hole but I knew they were filled up.
  4. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    really?
    cool....thats kinda what i figured but....yeah...hehe
    thanks!
