Upper Radiator Hose - Continental (Goodyear) 62834
Discussion in 'Technical' started by MountainDrre, May 23, 2019.
  1. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    I ordered and installed the Goodyear, now Continental 62384 suggested in the Micah’s post below. The problem, as you can see in the photos, is the hose rests on top of the alternator ear, albeit barely. Is this the best I can hope for, or are there other hose suggestions? Photos installed would be great.
    CB0521B1-8E8C-412F-AC69-88BA80671311.jpeg BBAFB71F-9EE3-4262-9969-E6828E2F60FB.jpeg
    http://mmb.maverick.to/threads/efi-302-radiator-hoses.100533/#post-1025141
  2. mojo
    Looks like the correct hose; the alt. is much higher than stock location. I don't think it will be an issue.
    Krazy Comet likes this.
  3. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    Good deal, not sure if I can do much to adjust the height of the alternator without changing the bracket, but there may be some adjustability, I will check tonight. It’s more bothersome to me aesthetically.
  4. mojo
    Looks like moving the adjustment rod to the next bolt toward pass side and longer belt may solve the issue.
    71gold likes this.
  5. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    I will look into that, thanks mojo!
  6. Hotrock
    Munroe Falls, Ohio
    Actually a shorter belt leaving everything else as is may be be the easier solution.
  7. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    Interesting. I think I’m following you. No way to rotate the bracket btw.
  8. mojo
    A shorter belt will not improve aesthetically under hood appearance -- alt. will still be up higher than stock.
  9. 71Mavrk
    71Mavrk Member
    Nevada
    My issue was a little different that yours. I'm running the 5.0 serpentine. The alternator sits a little lower than yours.
    Micah
  10. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    I see that, looks like AC and PS as well.
  11. bmcdaniel
    I just used the old 302 brackets to keep the alternator low.
    Krazy Comet and dyent like this.
