Useless Parking Brake
Discussion in 'Technical' started by Jony, Jun 6, 2016.
  1. Jony
    Jony Banned
    1972 Ford Maverick Grabber 5.0L 302 v8 NA
    So currently my parking brake is useless and i've had it for about a year now yet never really bothered to fix it since mainly because there were other issues needed to be taken care of. I dont know where to exactly start on this. Does any one know how to fix it? Right now I can pull it back to its extent but as soon as I twist it it friezes 1/4 of the way. Not sure if I have been using it wrong or not, i've been following the manual but it never works. Please let me know what should I do!
  2. rthomas771
    Cables could be in need of a good cleaning and greasing. The wheel the cable rides in could be worn out. Could need adjusting. You need to look at it and the answer might be looking back at you
  3. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Take a few photos of your cable system beneath the car and we might be able to see your problem.
    MD
  4. MaverickEsquire
    MaverickEsquire Member
    NC
    1971 Maverick 2-Door
    My parking brake locked up one day where I couldn't move - I removed it from the drum and never looked back :chirp:
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The cable wheel is probably worn out, which means the entire pull-handle assembly would need replaced. It's a real P.I.T.A. with the engine installed, as there is a clip on the firewall where the cable attaches to that must be removed.
  6. Jony
    Jony Banned
    Nevermind I figured it out when I went to get my overheating issue checked. The mechanic told me where and what to check and it turns out the the line wasn't properly connected! Thanks so much for helping, most of this helped out a lot!
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Oh, that's good it was something simple. I just figured you'd already checked all that.
