V8 clutch setup
Discussion in 'Technical' started by jpollard, Mar 29, 2004.
  1. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    1. Ok...here is my plan. I am going to take all the I6 clutch frame mount off the I6 car and put it on the V8 car. Then I am going to use a 69 mustang z-bar and modify it to fit the I6 frame mount. Will this work or is there an easier way??? Do I need a v8 frame mount or are they they same for will the mod be pretty much straight forward. This is all I have to work with.....do I need something else?
    2. Would it be easier to use the complete I6 setup and weld on the lower portion of the mustang z-bar to the I6 z-bar to fit the toploader bell housing? (this sounds easier)
    top loader
    Advice please....this is driving me crazy. Thanks.
    JP
  2. rx7351w
    rx7351w Member
    knoxville, tn
    74 2 door Maverick
    What did your toploader come out of? Mine came out of a 81 capri so I went with a mustang cable set up. It was pretty easy. removed pedal box, drilled a hole for the transfer tube and mustang clutch. I searched and found another member had done it this way but i dont remember his name. I have pictures of both pedal boxes and then the maverick box with the mustang clutch pedal in it. I have a little trimming to do to the wiper motor bracket which I didnt think I was going to have to do.
  3. jpollard
    jpollard Member
    Montana
    mine is out of a 69 mach I....thought it would be a good donor for the Mav! :) I have all the older linkage.......
  4. bmcdaniel
    Don't know about '69 Mustang linkage, but I'm using '66 289 Mustang linkage in mine. Also using the original Mav 6 cylinder frame mount. Got the block stud mount from the same Mustang that donated the linkage. The early Mustangs and 6-cyl Mavs used the same diameter bushings, V8 Mavs had the goofy 2-piece z-bars and huge bushings.
  5. bmcdaniel
    BTW, the 6 cyl. frame bracket that was in my Mav had the stud swaged into the bracket. It broke loose after awhile, so I pressed it back in and welded it on the back side. You might want to do that ahead of time.
  6. jpollard
    jpollard Member
    Montana
    It looks like I will be going with the 6 cyl setup and modifying the lower bar to work.... This is the last hurdle to get my car on the road!!!
  7. bmcdaniel
  8. Mavaholic
    When I first put a 302 in mine, back in the early 80's, I use my 6 cyl set up. I believe the lower arm on the Zbar was the only thing I had to modify. It worked like a charm for many years.
  9. jpollard
    jpollard Member
    Montana
    Man (or Mav) am I glad to hear that. It makes things a lot easier! Thanks guys.
  10. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Pollard, if you decide not to cut it up and go a different route, I have a 69 Mustang itching for a 4 speed conversion.
  11. jpollard
    jpollard Member
    Montana
    Sorry, most of it has been parted out and is gone. I do have the complete/original (air cleaner to oil pan and fan back) 351W that I am putting up for sale and some other misc parts.
  12. Max Power
    St. Paul, MN
    Already got a 351 that needs rebuilding. Gonna make a 393 stroker with the Edelbrock RPM package on it.
    I think my FMX will explode!
    Do you still have the clutch pedal assembly, or are you using it in your Mav?
  13. jpollard
    jpollard Member
    Montana
    All I have left is a z-bar....
