V8 swap help please!!
Discussion in 'Parts Interchange' started by Llamaface, Nov 2, 2015.
  1. Llamaface
    Llamaface Member
    1973 ford maverick
    The engine I bought has a 157 teeth 50 oz. on it. Is this compatible with my 1973 250? Also what water pump do I need. Everyone says late model, but I'm unsure what that means. Also what power steering unit do I need for the new engine?
  2. Llamaface
    Llamaface Member
    1973 ford maverick
    Also when I bought the engine I was given the torque converter,bell housing, and headers.
  3. x72COMETx
    x72COMETx Member
    Vallejo CA
    when i did my V8 swap from my 250 inline 6 i reused the torque converter and flywheel, just buy a water pump for a 73 302 that would be late model, newer model is like whats on 80s and 90s mustang, you will have to buy a new v8 power steering pump as they are different then the inline 6 pump,
  4. Krazy Comet
    "Late model" means for later model engines which with 5.0 is only partially correct... Yes the '73 pump will work as will one for a 5.0 Crown Vic up through 1991(it will be aluminum)... You do not want one for late 5.0 Mustang, T-Bird etc as those are reverse rotation(won't fit anyway as bolt spacing on pump hub is wider than on the std rotation)...
    Assuming your engine is newer than '82, the 157T 50 oz flexplate is correct for a case fill C4, which AFAIK was the only version used in Maverick... Bell housing and torque differ for 170/200 but should be same on 250 as is the 302 & 250 radiators...
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    The million dollar question, what did the engine come out of? Without that tid bit of information, every recommendation for a water pump is nothing but a guess.
  6. Llamaface
    Llamaface Member
    1973 ford maverick
    1987 mustang
  7. Llamaface
    Llamaface Member
    1973 ford maverick
    Also thank you everyone for all the help. You guys are a life saver!!!
  8. Llamaface
    Llamaface Member
    1973 ford maverick
  9. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
  10. Llamaface
    Llamaface Member
    1973 ford maverick
  11. Llamaface
    Llamaface Member
    1973 ford maverick
    Can I use the pulley from a 250 or do I need the v8 for the water pump?
  12. Llamaface
    Llamaface Member
    1973 ford maverick
    Also, what's the difference in grooves I.e. Single and three groove water pump pulleys
  13. Llamaface
    Llamaface Member
    1973 ford maverick
    As mentioned in an idiot. So I'm guessing I'll use the existing pump pulley on the engine. I'm just swapping the pump to the drivers side for the radiator. The pulleys are dual. Also all I needed was the drivers side pump (brand new not used) existing pulley from 302 and the v8 power steering. Now I just need a belt to connect the power steering.
  14. Cruzin Illusion
    1972 Grabber
    Just go down to your local parts store and buy one. Rock auto is an option if you really want to order online.
  15. RMiller
    Kennewick, WA
    I don't think you'll be able to run a v-belt setup with what you have. It's all based on the timing cover, I have a friend the tried to mount a standard rotation pump onto a reverse rotation timing cover and it wouldn't hold water. He ended up getting a different cover to match the pump. Take this for what it's worth, which isn't much, my experience is limited to his nightmare and that's the direction he had to go.:beerchug:
