Valance Bolt Type & Size
Discussion in 'Technical' started by kukm66, Jul 31, 2008.
  1. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    I found a decent valance as mine did not have on when I bought the car. I have a 72 Grabber. I noticed that there is a round hole with a square slotted bracket attached to the valance. This leads me to believe that a carraige bolt would be used. Is this correct and what size and length were the stock bolts.
  2. 71gold
    it is not a carraige bolt...
    it has a funky head on it that locks into the hole..i am sure you can use a different bolt but i have no suggestion of a size or kind...:huh:
    ...:Handshake...
  3. rthomas771
    About any Mustang shop has them for $4.00 each...they also have the next size up for one dollar. You will need to grind the square shank or open up the slot in your valance panel to save the dollars.
  4. kukm66
    kukm66 Member
    Phoenix
    Jeff:
    Is that a pic of a Mustang bolt or a Maverick?
  5. Dave B
    There the same, plus you'll need a screw kit for across the top.
  6. Craig Selvey
    I have found that a Maverick uses a smaller....but longer bolt than the Mustang. AMK sells them.
  7. Dave B
    Hmmm, I thought I bought mine from NPD, but I could be wrong.
  8. just1993
    just1993 Mike
    Zionsville, PA
    70' & 71' 2 Door and 76 4 Door
    Just make your own out of a bolt and washer. Don't cost nothing. Works just fine for me and no one will ever see it.
  9. kukm66
    kukm66 Member
    Phoenix
    Okay, I went to the best hardware store in Phoenix and bought the following:
    2 hex bolts
    2 washers
    2 speed nuts
    2 fender washers
    2 hex nuts
    I slid the hes bolts and washers into the valance bracket holes from underneath and secured thiem with the speed nuts. Then I mounted the valance and used fender washers and hex nuts to secure the valance inside the trunk. This worked perfectly.
    Total cost: $2
  10. just1993
    just1993 Mike
    Zionsville, PA
    Glad it worked out for you. Even if you were building an all original show car. No one would ever know it was not original. :dance:
    SHHHHHHH don't tell anyone!!!
