Valance Part
Discussion in 'General Maverick/Comet' started by Renton5, Jul 23, 2016.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    Hello!
    I'm nearly done with the whole gas tank operation for my '71 Mav.
    I noticed on the rear valance--the part that the license plate attaches,
    concealing the gas tank--that the left side valance-to-lower trunk
    bracket is missing. It was originally spot welded, but sometime in
    the past millennium it must have fallen off. It's no big deal since I
    have all screws to fasten the valance onto the car, but I figure since
    Ford had it there, I ought to also. I've included a photo of the right
    side bracket. Anybody know where I can get one of these--when it
    goes in for a repaint, I'll have it welded on.
    Thank you!
    Renton5
    (Daniel)
  2. Craig Selvey
    A similar bracket is found on a Mustang valence. You could buy that, cut it off, and weld it to your valence.
  3. 71gold
  4. Renton5
    Renton5 Member
    Van Nuys, CA
    Hi Craig and Frank!
    Thank you for your responses! I think I'll forgo buying a whole valance,
    to get the part. Since it's been driving fine without it, I think I'll forgo it.
    Here's a new problem:
    In my '71 Mav, 200 engine, I just put in a new donut gasket at the exhaust
    junction. I turned the engine on for the first time since April--gas tank and
    carb issues--and at first there was no problem, then as the engine warmed
    up, I smelled something burning then turning it off, I saw smoke rising
    from what might be the junction area. The air cleaner heat tube plate (off
    the manifold) was blocking my view.
    There doesn't appear to be a fuel leak, no oil dripping, so I'm drawing the
    conclusion that because it's new, the donut is burning off some chemical
    residue or there was some remnant of the chemical cleaner the shop used
    when they rebuilt the carb...but it didn't look like it was coming from that.
    Any thoughts?
    Thank you!
    Daniel
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Did you get greasy replacing it, and did some of that grease get onto the exhaust manifold or pipe?
  6. Renton5
    Renton5 Member
    Van Nuys, CA
    Neither oil nor grease came in contact with the parts.
    I've done some research after I posted my query.
    It's looking like that due the composite nature of the materials
    (or production process) used in the "donut", the engine heat
    will "burn off" some of the outer surface. Today is Saturday
    as I write this, on Monday I'll call a couple mechanics and
    maybe a "donut" manufacturer to be certain.
