Valve cover suggestions . . .
Discussion in 'General Maverick/Comet' started by mashori, Jul 10, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Need some valve covers. Bryant has these on his car which I really like but they are hard to find online. They have the short ones but I want the tall ones and ideally in black. Are there other ones out there people use that are nice and solid?
  2. Mavman72
    These "boss" style covers from Ford racing are pretty tall and stand up straight on the verticle side making plug changes a bit easier.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I actually think that's what bryant gave me he had laying around. they look like they fit well but the baffles aren't there and I was trying to make some baffles for them but broke a screw inside the valve cover and gave up.
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  5. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Check out e-bay Mo, there are a ton on there.
  6. strokermaverick
    strokermaverick Member
  7. maverick75
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    so those holes in there, what are they for? do I have to have them because on my car they always leak.
  9. Alan Duke
    Alan Duke Member
    Houston, TX
    1973 Maverick
    Yes, you do need them one for the PCV, and the other to add oil. I guess you could get away with just one. If you are having leaks now and have no baffles, that is to be expected. Get the taller covers w/baffles and you should be OK. I am pretty sure Ford Motorsports still carries those .....and also in Black.
  10. strokermaverick
    The reason the holes "leak" is engine blow-by, which is is caused by worn, or unseated rings. A properly running engine will not have oil coming out of those holes, although you do need your pcv valve hooked up reguardless. My old 1970 f-100 does the same thing.:yup:
  11. Mavman72
    [​IMG]These are the covers I was referring to. I have them on my Sprint and like the room they offer...
