Valve Lash Adjustment
Discussion in 'General Maverick/Comet' started by lika, Sep 17, 2009.
  1. lika
    lika Señor Comet
    IA
    comet 71
    This video will work for the 302 engines ford ?????
  2. lika
    lika Señor Comet
    IA
    comet 71
    1-8-4-3-6-5-7-2 is this correct
  3. Dave B
    There is no last adjustment, on stock 302 rockers, you just torque them down, to the specified torque, for the year of your engine.
  4. Mavman72
    If you have a 302...you have positive stop valve train.Simply turn the rocker arm nut till it stops,then give it another quarter turn to cinch the nut so it wont back off,and your done.You do not need to follow any particular fireing order sequence to do this.
  5. lika
    lika Señor Comet
    IA
    comet 71
    Excellent! I'm so glad to learn this! Thanks!
    I did it like the video said but once I rotated the engine, one of the rockers became loose again. So, I'm just going to go around, loosen them up, tighten them and do the final 1/4 turn and I'll be done. Great!
  6. lika
    lika Señor Comet
    IA
    comet 71
    Thanks again!
  7. blugene
    There is a torque spec AND the push rod(s) has to be correct or it will damage things.
  8. lika
    lika Señor Comet
    IA
    comet 71
  9. blugene
    I prefer to use inch pounds when that low of torqueing. I kinda like the description of this one
    http://www.summitracing.com/parts/KTI-72130/ . Seems kinda pricy but goes up to almost 100 ft lbs. Does all three by the description. Eliminates needing different ones untill you get to the higher ranges. I have clicker styles and I have to pay attention cause sometimes it won't click.
  10. lika
    lika Señor Comet
    IA
    comet 71
    wow That's too much money :cry:
  11. lika
    lika Señor Comet
    IA
    comet 71
    I think I'm going to buy a used Wrenche!
    Gene
    How is your car doing??
  12. Dave B
    They (Ford) spec a torque for a reason, so I'd torque them...you don't need one to loosen off while driving .
  13. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    If you're going to work on engines you must have a torque wrench, IMO.
    Rotating the engine to find the low spots on the cam allows you to check the push rod lengths and lifter movement. I just did this on my engine. With the each cam lobe on the low spot, I turned the nut till the rocker just contacted the pushrod, then about 1/2 turn to finger tight would compress the lifter a little. Then about 1/4 turn would put them at torque spec. That gave me confidence the push rods were the correct length. If you're reusing lifters, that will also ensure none are stuck.
    If you're re-using the push rods, check the ends for wear. The end that had been in contact with the lifter will look new-- the end that had been against the rocker might show wear. Put the least worn end up.
  14. lika
    lika Señor Comet
    IA
    comet 71
    so which order must go? do you know ??
  15. lika
    lika Señor Comet
    IA
    comet 71
    a lot of good information!!!! i don't no what to do:biglaugh: !!
