vandalized !!!!
Discussion in 'General Maverick/Comet' started by bomrat, Sep 22, 2009.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    damn it. went to drive my car today, got down to downtown memphis and noticed my car wouldn't idle... ended up somebody screwed in my idle screws on my carb.. looks like they loosened two spark plug's too. number 1 and number 8... i now have rough idle, and an oil light on....
    i will have to check all the plugs, check the oil pressure, and readjust the carb if everything checks out...
    if not start looking for another engine, and get out the ar-15 !!!!
    next bastard that messes with my vehicles .....
    where is the oil pressure sensor on a 302?
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    it is above the oil filter
  3. comrick317
    comrick317 Banned
    Mississauga, Ontario
    1976 Mercury Comet
    That's just wrong, some real gutless goof to mess with someones car.
  4. CaptainComet
    Loosened spark plugs, especially one all the way in the back? ... too much work to be random (that takes more tools and planning than just a little pocket screwdriver) ... did you tick somebody off?... have some immature joker as a friend?
    I would bet that the oil light is on just because the motor is idling at too low of a speed. If it is still on at 800 rpm, the wire might not be securely attached to the sender, or it may be something more serious.
    One way to stop this from happening again would be to bolt a short piece of chain to the hood bracing, that is just long enough that you can padlock it to the rad support. You pop the hood open and leave just enough room that you can unlock it, but they can't lift it high enough to unbolt the chain or mess with anything.
    I think I also saw a tech article here about installing a remote hood latch.
  5. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    You can also weld a few tabs on the hood and rad support to have a combo lock, Works great unless you have a glass or carbon fiber hood.
  6. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Change your oil, just to be sure, and look for signs of sugar, sand, etc. around you gas cap... And find new friends!
  7. bomrat
    bomrat Member
    just moved to memphis,,,, don't know anybody except for like 4 people....
  8. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    1972 Maverick 2 Door Sport Sedan Grabber
    Lock and load baby, lock and load. Use the .357, .45 or 50 cal. for pick 'em up knock down power, and by all means don't hit the car! As we used to say in the Corps, dead men tell no tales! lol
    Seriously, I'd go with an up-dated/or quick lock for the hood since you are living in a larger city--its a simple inexpensive solution. And just a thought, any cameras around where your car was parked? If so, ck it out and you might be surprised in what you find! Cameras are everywhere these days.
    Good luck and sorry to hear of your misfortune!
    Stay tuned man and keep us posted on what happens or what you end up doing!
  9. facelessnumber
    Memphis, TN
    '71 Grabber
    Pretty weird. I wouldn't expect that kind of random sabotage in Collierville. That's kinda where people move when they want to get away from all that. Guess crime can happen anywhere though...
    Well hopefully you'll make that number a bit higher Thursday night, if this rain ever backs down...
  10. obmav
    obmav Greg Garrison
    olive branch, ms
    partial owner/ 1973 Maverick
    Hey from the OB.:HandshakeWe have several cruz-in,car shows ect in the "memphis"area, oh OB(Olive Branch ms) just southwest of you.Good looking comet:thumbs2::bananaman
  11. darren
    Yeah baby Ar-15. What a fool to mess with a mans car. Especially one protected by an AR-15.(y)
    Just make sure you dont miss and hit the car. :hmmm:
  12. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Sorry to hear,,, are you sure someone was messing with it?? #8 plug would be a last choice. I'm hoping just vibration caused the problem. Good Luck
  13. sierra grabber
    sierra grabber Certifiable
    northern nevada
    that stinks and i agree with many others that it wasnt random!
    off topic, MAVOWAR?! how you hangin in there? hope alls good!
  14. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    I say you run the idiot over with your car. My upper rad. hose was cut a couple weeks ago and I've been trying to figure out whos ass I need to kick.
  15. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    that sucks man,i had someone somehow remove the brake fluid from my master cylinder one night,now i have the chain lock.
