vin location
Discussion in 'General Maverick/Comet' started by elgatovenus, Apr 4, 2011.
  1. elgatovenus
    elgatovenus Member
    monterrey, mexico
    maverick 73 2 door 200cid v6
    hello, im trying to locate my vin code, i have searched in the dash panel, and the door,tehere is nothing, is there another vin code?, on the chassis or any other side, help me please, if you have pics, much better, my maverick is a 1973, almost that says on the invoice (factura mexicana).
    Gracias, sorry for my english.
    :thumbs2::thumbs2::thumbs2::(
  2. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    Should be on the dash in front of the steering wheel by the windshield.
  3. kyle1972
    kyle1972 Member
    Modesto California
    1972 4 door Maverick 250 I6
    if you look from the outside down on the bottom drivers side you should mabye able to see the vin on the back of the dash...if that makes any sense or is any help.
  4. Craig Selvey
    Maybe mexican Mavericks don't have VIN. I know stolen Mavericks usually don't have one. :D
  5. maverick@heart
    maverick@heart Member
    Hendersonville TN
    1975 American Maverick, 1976 Mexican Maverick, 1973 Maverick
    No, no, no guys,! The vin number on a Mexican 73 is on an aluminium tag attached to the drivers door under the latch mechanism.It is not riveted but glued and many times it is either missing or covered up on repaints.
    The one other place to look for it is under the front fenders where they are attached to the front clip. They have this serial number stamped on the sheetmetal.
    Mexican mavericks did not have the vin numbers on a dashboard plaque like their USA counterparts. I know this. I have a 76 and a 73 both built in Mexico
  6. kyle1972
    kyle1972 Member
    Modesto California
    oh, well learn something new every day lol i wouldve thought theyd all been in the same place.
  7. maverick@heart
    Hendersonville TN
    Come to think of it and judging by the description given on your info under your user name I am starting to wonder if you have a mexican or american built maverick. Since Mexican Mavericks did not come with 2oo cid. engines but either 289 or 302 cid.s
  8. elgatovenus
    elgatovenus Member
    monterrey, mexico
    Re
    My mavick, as says my son ejjejejeje, is a 6l, i assume is a 200 cid. or im wrong?
  9. elgatovenus
    elgatovenus Member
    monterrey, mexico
    re
    Dont have it, and in the dash panel rear the windshield either.
  10. maverick@heart
    Hendersonville TN
    Los mavericks gabachos salieron con motores de 6 cilindros en linea con 200 cid, 250 cid y otro motor mas chico y menos de 200 cid.
    Los mavericks mexicanos solo salieron con motor 289 y 302 cid y son de 8 cilindros. En el 73 creo que salieron con L200, L250 y V8 302.
    Si tu carro es hecho en Estados Unidos o Canada forzosamente debe tener el VIN visible en la esquina inferior del parabrisas en el tablero.
    Si es hecho en Mexico lo debe tener debajo del mecanismo de la cerradura en una de las puertas y debajo de las salpicaderas de enfrente. Solo que para buscarlo ahi tendrias que remover las salpicaderas.
    Saludos y suerte
  11. elgatovenus
    elgatovenus Member
    monterrey, mexico
    Gracias
    Hola gracias, por tu interes.:thumbs2:
    Pues el de las salpicaderas creo que es mi ultima opcion, gracias por contestar tan rapido, es un foro muy activo, en el tablero no esta, si esta el espacio pero el pedazo de aluminio con el vin,no esta, en la chapa del puerta tampoco, espero que en la salpicadera si este, ya me intrigo eso, espero no encontrarme con una mala noticia, despues de eso habra alguna otra opcion, ¿chasis o pared de fuego?:huh:
    Saludos.:thumbs2:
  12. maverick@heart
    Hendersonville TN
    Creo que es fundamental que identifiques tu auto como Americano, Canadiense o Mexicano. asi comenzariamos a buscar el VIN a traves de las carroceria.
    Suerte
  13. elgatovenus
    elgatovenus Member
    monterrey, mexico
    quiza americano.
    Pues la verdad creo que es gringo, porque las aletas traseras vienen las leyendas en ingles, pero de ahi en mas no sabria porque decir si es gringo o mexicano.
  14. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
    I have seen a picture of a Mexican Maverick that does have the rivits on the VIN, on the driver's side door. Maybe they changed from year to year.
  15. maverick@heart
    Hendersonville TN
    Pudiera ser relativamente facil distinguir entre mexicano o americano.
    El americano tiene el velocimetro en millas y el mexicano en kilometros.
    el americano trae cinturones de seguridad para los pasajeros de atras y el mexicano no los trae.
    El mexicano no tiene desempañador ni calefaccion y el americano si lo tiene. y el mexicano solo salio de fabrica con un motor 302 de 8 cilindros y son rarisimos los mavericks mexicanos que son automaticos. Tal vez esto te ayude un poco.
