Voltage regulator controling gas tank sending unit
Discussion in 'Technical' started by stevelonie, Jul 12, 2006.
  1. stevelonie
    stevelonie Member
    Washington
    Does anyone know where the voltage reg on a 70 Mav that supplies power to the fuel sending unit is located.Is it on the back of the dash? Left,center or right? It probably is rectangular, about 1.5" by .75" with two terminals? Any help would be greatly apreciated. :huh:
  2. Mavaholic
    It is mounded on the back of the dash (gauge assembly). I dont remember exactly where but it is a small rectangular piece as you described. Easy to spot.
  3. Jamie Miles
    Alto, GA
    I've had a few
    Yep, on the back drivers side of the gauge cluster. It's metal, held on with 1 screw.
