water pump pulley help
Discussion in 'Technical' started by carcrazy1964, Aug 21, 2022.
  1. carcrazy1964
    carcrazy1964 Member
    1976 ford maverick
    i just intalled after market power steering bracket and alternator on my motor power steering appears to run off just the crank and alternator appears to have to run on both the crank and water pump pulley when i put water pump pulley on it sits way to far back ...can anyone tell me whats going on here
  2. Krazy Comet
    P/S & water pump driven by inner groove on lower pulley, alternator by center or first.
    You have wrong pulley(offset), appears to be 6cyl.
    carcrazy1964 likes this.
  3. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Looks like the PS pulley is on backwards and that non factory bracket has the pump too far forward. The correct SBF brackets are easy to find, you need the bracket that attaches to the pump and head, and pump to WP adjustment bracket. You can see them both in Tom's picture.
    mojo and carcrazy1964 like this.
  4. Krazy Comet
    The 6 cyl pulleys have a inverted offset, matches forward groove on pulley.
  5. funkyole
    funkyole Member
    Homewood junction
    1970 maverick grabber
    Right pulley wrong p/s bracket. also the alternator pulley is wrong, should be single groove. dont forget the spacer behind the p/s pump also!
    back this horse cart up! you need the bracket on the pump itself also! thats why it looked so off!
    bracket d1za-3c511-ab
    pump bracket D0AZ-3A732-C
    Couldn't locate the part number for the spacer.
    Krazy Comet likes this.
  6. Krazy Comet
    Supposedly the spacer has a base number of xxxxx but I didn't find it in Master Parts.
    EDIT
    Actually base part number is 3D600. For '70/'71 & '72 Mustang/Maverick 302 should be this one. Spacer is 9/16" thick.
    https://www.npdlink.com/product/spacer-power-steering-pump-mounting/148924?backurl=search/products?search_terms=c8sz-3d600-a&top_parent=0&year=
    I'm glad this came up, my Comet has stack of washers inside large heat shrink.
    funkyole likes this.
