Water Pump
Discussion in 'Technical' started by MarulMav, Dec 10, 2006.
  1. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    I read that late model (82 & later) 5.0 HO's use a reverse rotation water pump. Does this mean I am not able to use my '75 water pump on my new '85 HO? Thanks
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    You putting the HO in a Mav?
    If so, you just need to use the old style timing cover and pump.
    You will also need to run regular vee belts.
    If you intend to use the serpentine system, you must use the HO pump, cover, and pulleys.
    Dave
  3. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    Yup, I did place the old cover and pump on it, just wanted to make sure that was correct. Thanks.
