Water pump
Discussion in 'Technical' started by angusbull, May 18, 2012.
  1. angusbull
    angusbull Member
    Florida
    1972 Grabber
    Will the water pump for a 1972 302 work on a 1985 block?:hmmm:
    1.Carborated
    2.v-belt pulleys
  2. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    It won`t work on it, you have to work on it water pumps are lazy like that. It will fit though.
  3. angusbull
    angusbull Member
    Florida
    1972 Grabber
    Would it cause a vibration if it were installed?
  4. Mavman72
    Not unless the shaft were bent or ready to fall out of it...Or you have bent/imbalanced fan on it...I take it you have a vibration issue???
  5. baddad457
    You're asking the wrong question. It's not the block it's got to work with, but the timing cover. If you have an 85 timing cover, it'll work. If you have an 86-97 5.0 cover from a Mustang or pickup/van 5.0 it won't.
  6. bmcdaniel
    bmcdaniel Senile Member
    Or, as in my case, '89 5.0 block with a '74 timing cover and water pump. The later timing covers are located on the block by dowels, just remove the dowels to use the old cover.
  7. baddad457
    Better yet, use a timing cover from any 1980-up Crown Vic, these all use the dowels to position the cover correctly for the front seal to do it's job. Same cover you're using now, only it's got the dowel holes
  8. angusbull
    angusbull Member
    Florida
    1972 Grabber
    Yes, I've been chasing one for a year now. I think I've narrowed it down to either a cam or crankshaft issue, everything else has been replaced.
