what are they called!!!!
Discussion in 'Cosmetic' started by Tomcats90, Apr 19, 2015.
  1. Tomcats90
    Tomcats90 Member
    South gate ca
    73Ford maverick
    like the title says wat are those things on top that holds down the vinal and how do I remove them?Yeah I know small pick but it a wat I gots:):)
  2. Craig Selvey
    That is your drip rail and those are the drip rail moldings.
  3. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    I believe what is circled is the vinyl top trim used on 73-75 models. It is held on by small plastic clips that can be purchased new at Melvins Classic Ford. You can use a small putty knife to unsnap the trim at each clip. However, in the rear, the small 2 inch section that turns and goes back toward the rear window trim, it is held on by a clip using a stud and nut. Open the trunk lid and reach under to locate and remove the nut.
  4. Tomcats90
    Tomcats90 Member
    South gate ca
    73Ford maverick
    Awesome that's really good help thanks guys
