What C4 is this transmission
Discussion in 'Transmissions' started by abesshop09, Dec 23, 2018.
  1. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    1970 Maverick, 1998 Explorer Sport
    I know that this is an old thread but I am trying to find out if the C4 I have is off a 200 inline 6cyl or V8, the car is a 70 and had the 200 in it, but the person I bought it from was doing a v8 swap using a 74 donor car which he took the front disk from and rear-end and but on the 70.... here are the pics of the tranny...….
    thanks for any help with this
  2. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    1970 Maverick Grabber 200/six, swapped to 306ci
    How many teeth does the flexplate have? If I am not mistaken; 148 tooth for 170, 200.
    153 tooth for 250 and 302.
  3. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    I don't have the engine just the trans in the pics
  4. Krazy Comet
    Low mount starter V8 or 250 6cyl. 200 had starter two thirds up bell.
    The 4K104752, ID as from a '74 model.
    Other than bell, externally V8 and any six cyl are same. Though there are differences between 1969 & 1970 models.
  5. baddad457
    That was 147 tooth. The Mustang II 302 also used this. The 153 should be 157 tooth, that's a case fill C4. Trucks got a 164 tooth pan fill HD C4.
    Krazy Comet likes this.
  6. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    If there's a metal tag on it somewhere that would give you more info on it but at this point especially if there's no tag it's been rebuilt or something and all bets are off.
  7. Krazy Comet
    Who can say it hasn't been rebuilt and tag reinstalled?
    The 4K104752 stamp means trans was installed by Kansas City assembly into a 1974 model. Being KC built Maverick, not much doubt it was original transmission from the '74 Maverick parts car. The large reuilders usually cut this stamp.
