WHAT DIFF IS THIS
Discussion in 'General Maverick/Comet' started by Aussie, Mar 9, 2019.
  1. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Hi folks. Who can help me with the identification tag i have on my differential on my Maverick here in Australia.
  2. William623
    Orlando
    1973 ford maverick grabber
    6 cylinder car with 8" 2.79 gearing.
  3. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Thank You
  4. rthomas771
  5. Aussie
    Aussie Member
    Australia
    1973 Maverick
  6. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Ok what diff centre do i have here. It is a locked diff so is it supposed to be or has it been messed with. Thanks for your help.
  7. Krazy Comet
    Divide number of teeth on pinion gear into number on ring gear, that'll give ratio.
    The 9H23 is casting date -- 1969, August, day 23. Not likely original to a '73.
  8. dyent
    dyent Member
    vancouver bc
    according to your tag WDW-T is 2.79 ratio used in 71-73 Comet/71-74 Mav and is an open diff, not a Trac-Lok..........
    Also, Ford Equa or Trac-Lok differential covers have a counterbore below the bolt heads and are also smaller in diameter, I believe 5/8" for lockers versus 3/4" for conventional.
    David
  9. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Thanks guys. I am wondering if it has a Jegs Powertrax non slip in it. Can anyone tell just by the pics or would i need to pull it apart.
  10. dyent
    dyent Member
    vancouver bc
    First, have you determined if the ratio is 2.79? It is highly unlikely, someone would go through all the trouble of installing something like a Powertrax unit, keep the 2.79 gear ratio and still have the ID tag! With the Powertrax unit, the spyder gears are removed, so you might be able to look through the hole in the side of the carrier to see if they are still there. It looks like you have a 2 spyder gear unit, did you remove the center section from your car or this is something you purchased? If you have both axles, you can insert into the carrier ends, clamp/secure one axle and see how much effort it takes to break loose/turn the other axle. It will take a fair amount of effort to break loose, thus you have a "posi", otherwise the sure way to tell, take it apart.......
    David
    how did you determine it is a limited slip? did you actually have it in the car and have both tires lock up? or did someone tell you it was a "posi"?
    Aussie and Krazy Comet like this.
  11. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Thanks everyone. The diff is out of this car and the ratio is 2.79 as i just worked out from Krazy Comets post. When i turn the inside tyre fights against the other and both wheels spin together when jacked up off the ground. I cant see any spyda gears inside as in the pic below. When i look through where the axles go into the diff centre all i can see is the pin and all the splines.
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Looks like a mini spool.
  13. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Mate i reckon you are right. I have just had a look at them and yep looks the same
