What else am I missing ?
Discussion in 'General Maverick/Comet' started by Richard Kuss, Nov 5, 2016.
  1. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    Redoing my front suspension and part of my steering in my 70 next month I've placed two orders from rock auto so far.
    Here's what I have
    MOOG:
    Upper ball joints
    LCA/w ball joints
    Strut rod bushings
    Inner tierods
    Outter tierods
    Tierod Adjustment sleeves
    CALVERT 90/10 shocks.
    I decided after I made my first purchase that I want to buy the MOOG UCA assembly. so the ball joints I have are useless.
    I also want to replace my spring perches and debating buying new set of MOOG coils since they're less than $60.
    I'm leaving the sway bar alone for now because I plan on upgrading it soon.
    Questions? comments? concerns?
    Anything I should add?
  2. 71gold
    zerk fittings...
  3. mercgt73
    mercgt73 Member
    Pitman arm bushing and idler arm?
    Richard Kuss likes this.
  4. Richard Kuss
    Red Bluff Ca
    For ? from what I can tell all the moog stuff came with em
  5. 71gold
    are they...straight or 90s?
  6. CaptainComet
  7. William623
    Orlando
    1973 ford maverick grabber
    The roller spring perches are definitely worth it. You can feel the difference while driving.
  8. CaptainComet
    The strut rods are under a pretty good load. Not knowing about the issues with poly bushings and strut rods not working well, I snapped a strut rod. Luckily it was low speed going over a speed bump. Ripped the steering wheel out of my grip. Would have been ugly at any kind of speed .... would have pulled me head on into traffic going the other way. Lucky that day!
    My point is if a side load can snap one merely because I replaced a rubber bushing with a stiffer one, maybe it should have been made to move freely in the first place.
  9. Richard Kuss
    Red Bluff Ca
    That's worth keeping an eye on... I bought the moog replacement rubbers. so hopefully I'll be good. I think the only poly bushings I have are on my sway bars
  10. CaptainComet
    Poly is fine anywhere else in the front end. I used polygraphites, the whole kit, from PST and they have been quiet. Noise is a common complaint with some brands.
