what flywheel to use
Discussion in 'Technical' started by driftwood, Feb 22, 2013.
  1. driftwood
    driftwood Member
    aberdeen,oh
    95mustang gt convertable 74 maverick, 75 four door,71 parts car, 67 couger 71 jav. sst
    hi huys, i need some help i have a 1977 302 i'm putting in a 1975 four door maverick that has the original I-6 tranny c-4 3 speed that i'm gonna bolt to and i need to know the diameter of the fly wheel. i don't remember what size tranny i jerked out of there,its been a year since i took it out and it didn't say on the top of it as i remember. thanks ahead of time
  2. baddad457
    Most likely a 157 tooth flexplate/flywheel. The imbalance factor depends on what year 302 you're using.
  3. driftwood
    driftwood Member
    aberdeen,oh
    it is a 1977 302 i edited it just now thanks isthat the right one to use?
  4. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Was it a automatic trans? If so , it was a C-4 3 speed.
  5. driftwood
    driftwood Member
    aberdeen,oh
    yep, crap! lol things that are in my head i just think people know. c-4 three speed thanks
  6. John Holden
    John Holden Member
    NJ
    Was the original engine a 250? If not, the trans won't fit the 302.
  7. Krazy Comet
    The 200 C4 trans could be used, just not the bell and maybe torque converter...
  8. John Holden
    John Holden Member
    NJ
    Let me re-phrase that. If it wasn't a 250 then the trans will not bolt up to the 302 wuthout modifications. If it was a 250 the whole thing including flywheel and torque converter will bolt right up to the 302.
  9. driftwood
    driftwood Member
    aberdeen,oh
    yep its a 250 isw the 157 tooth flywheel right then?
  10. baddad457
    That depends on the imbalance factor of the 250 flexplate. I know the 300's used a neutral balance flexplate, not sure about the 250's. A 77 302 needs a 28 oz/in flexplate.
  11. John Holden
    John Holden Member
    NJ
    I'm pretty sure all the 250's are 28 oz imb. It should all bolt up to the 302 and work correctly.
  12. driftwood
    driftwood Member
    aberdeen,oh
    i'm not using the 250 flywheel.i looked up the engine code using a thread in here and it was a 250. i bought a 157 tooth new flywheel for it.hopefully thats the one i need. :)
  13. baddad457
    If you bought a flywheel, then you're in for a big surprise as a flywheel is used with a manual transmission only. You need a flexplate for an automatic transmission.
  14. John Holden
    John Holden Member
    NJ
    Ok if it onset work you can use the 250 flywheel or send it back and get your money.
  15. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    According to fordsix.com, the 250 and 302 have different imbalance.
    http://www.fordsix.com/250swap.php
    IIRC, the 250 has a zero imbalance.
