what is this part ?
Discussion in 'Technical' started by pattyderome, Nov 20, 2013.
  1. pattyderome
    pattyderome Flying Comet
    Québec, Canada
    Mercury Comet 1976
    What is this parts ? and it's necessary to have ?
    thanks
      File size:
      139.2 KB
      94
  2. x72COMETx
    x72COMETx Member
    Vallejo CA
    I think that is a carbon canister i dont no if its needed so i took mine off
  3. Krazy Comet
    It absorbs fuel vapor from the tank, then routes them into the air cleaner to be burned rather than vented into the atmosphere... If you have a visual emissions equipment inspection your car could fail without it...
    As far as operation, their will be no difference with or without it...
  4. MSmithPDX
    MSmithPDX Member
    Portland, OR
    That is the carbon canister which acts as a air purifier for fumes from the fuel tank. If you don't mind your underhood area filling with active fuel vapors you can remove it.
  5. pattyderome
    Québec, Canada
    Mercury Comet 1976
    Ok thanks for the information !and where a plug the hose if I have an air cleaner Hi-po style ?
    thanks
  6. Dave B
    Do you have emission testing in Quebec? Here in Ontario, we don't on older cars, but we can be pulled into inspection, and if we don't have it, we get a fine. They have been know to set up mobile inspection stations , outside car shows and cruise nights...
  7. pattyderome
    Québec, Canada
    Mercury Comet 1976
    yes, we have emission testing in Quebec
  8. Dave B
    We've been told, if it came with it from the factory, it has to be in place on the car...regardless of the year.
  9. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Not sure what you mean by Hi-po style. Aftermarket? Many aftermarket air cleaners have knock outs for those connections.
  10. simple man
    simple man Member
    Bunnell,Florida
    If yours is in that good of shape, I would certainly keep it! I can't even find the hose for mine! (at least for a reasonable price) This idea may be wrong, but in theory the canister collects fumes from the fuel tank and stores them in a charcoal media to be burned once the engine is running. So in doing this wouldn't the fuel mileage be better? You would be using otherwise wasted fuel vapors. :)
  11. kboldin
    Santee, CA.
    This is one of my giant pet peeves…. I won’t get into the emissions part of it but I will say this is flat out harassment. Targeting people outside of car shows is not equality under the law, randomly testing on any given day or as part of registration is one thing (I don’t agree that either) but to actively target groups of people is despicable. We have a similarity in southern California, they come after law abiding citizens but turn a blind eye toward every vehicle coming up from Mexico with their crap gasoline. It’s absurd…
  12. pattyderome
    Québec, Canada
    Mercury Comet 1976
    I don't have knock outs on my new air cleaner.. Do you have idea where I can plug the hose
  13. Jsarnold
    '72 Sprint
    I'd make a hole in the bottom of the air cleaner, inside the filter, stick the hose up into the air cleaner and secure it somehow. Maybe a hose clamp to stop it from falling back out.
  14. simple man
    simple man Member
    Bunnell,Florida
    You could use a crankcase breather filter through your hole. It would be held on by a clip and have a protruding barb to put the hose on. It is found on a lot of Ford vehicles. :)
  15. cougargt
    cougargt Member
    One of the two smaller round holes in your canister is for the vapor connection. The other is for the crank case ventilation. You just need to buy the correct adapter for it. Most likely the one nearest to the large snout opening.
