What other rear ends will bolt right up on my 70 maverick?
Discussion in 'Parts Interchange' started by qpdcqp, Jul 21, 2011.
  1. qpdcqp
    qpdcqp Davon
    Yuba City Ca.
    70 Grabber Maverick, 75 2dr maverick
    I'm 17 and not very smart so I need all the help I can get! Hahaha. Iv seen other forums but I'm still not %100 clear on what I need to do. I'm looking for a 5 lug rear end that will just bolt right up. So a list of what model and year of cars with rear ends that will work would really help out! Thanks. Davon:huh:
  2. don graham
    Any 8" out of a Maverick or Comet will fit and bolt right in.:)
  3. Acornridgeman
    Wisconsin
    :Welcome:
    I would just look for a donor Maverick rear. They are easy to find. If you can find an 8 or 9 inch from a Granada or Monarch, they also bolt right in. The Lincoln Versailles was the hot ticket a few years back, to get the disc brakes, but they are expensive to restore.
  4. qpdcqp
    qpdcqp Davon
    Yuba City Ca.
    Thanks! Like I said every little bit helps!:urock:
  5. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    There is a complete though rusty on Sacramento Craigslist for 550
  6. Payette 302MAV
    Payette 302MAV Member
    Payette Idaho
    1970 Maverick 302 painted Bahama Blue Metallic.
    my car was a 4lugger to start out. i took a rear ended out of a mustang which happened to be 8 inch and swapped leaf springs from my 4lug axle to the 8 inch axle and it bolted right up. i also ended up putting on air shocks too. it was a pretty easy deal.....
  7. Payette 302MAV
    Payette Idaho
    an older mustang for your info. like 60s and 70s....
  8. rayzorsharp
    They are wider so you'd have to use deeper offset wheels to keep the tires inside the wheel wells.
  9. Michael lynn75
    Michael lynn75 Member
    Keller Texas
    1975 comet
    I have a similar question but more in a performance way. I have finished up my motor and tranny and now am looking for a rear end. I am on a budget so i can not go to wild with one.
    Im mainly looking for one i do not have to shorten, everything else i will be changing anyway. The best I can tell there is no stock 9 inch that will work. But the 8.8 should. Im currently looking at a 8.8 out of a fox body thats already built up to just about what I want. Im told it will work but just wanted to know if there was anymore info out there and if there was a sheet with axels that fix closely with our cars without having to be shortened.
  10. baddad457
    Someone told you wrong. The Fox body and newer Stang 8.8's are wider and use a completely different suspension (4 link vs your leaf springs) Probably the most cost effective, easiest to find 8.8 is those from the 94-2001 Explorers. These all have 31 spline axles (vs the Stang's 28's), many have traction loc and better gear ratios such as 3.55 and 3.73's. A very few had 4.11's. These rears are also not a bolt in deal, but are easier to fit in a Mav than a Stang 8.8.
  11. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    ther is also a 9 inch that fits IIRC it is from an OLDER car like a 50 someting but I cannot remember what kind of car it was off the top of my head but I bet if you do a sear on 9 inch rear you would find it
  12. DaMadman
    Southern MD
  13. Red1972Grabber
    Northern California
    I recently bought a '77 Versailles to use the posi rear end and front & rear disc brakes on my '72 Grabber. Why are they so expensive to restore?
    Esakan likes this.
  14. baddad457
    They're not really. Just a few dollars more for the calipers and rotors compared to other applications, if you have to replace these parts.
  15. Michael lynn75
    Keller Texas
    1975 comet
    He was saying he had a friend install one out of a same year car into a maverick.
    This is the posting :"I have a built 8.8 rearend out of my 93 coupe,it has a eaton posi unit,31 spline strange axles,355 gears,welded axle tubes,half inch studs,c clips,and girdle,comes complete with brakes and emergency brakes,all fresh,if interested give me a call at 214-881-3178,you cant find a better deal for 550 bucks"
    It looks good and apparently he has a receipts for everything. I can put pearches and shock mounts and the rest, im just not wanting to narrow the rear end is all.
