What size speakers fit the rear window?
Discussion in 'Audio' started by TUK101, Mar 5, 2009.
  1. TUK101
    TUK101 Member
    Elk WA
    72 Maverick 4dr/302 V8, 1963 Ford Custom 500 inline 6
    Just looking through the trunk, the speaker holes for the rear window appear to be 6X9's, but I have made the mistake with Fords before and they have been 5X7's. Anybody know for sure so that I don't have to crawl into the trunk to measure?
  2. hacksaw415
    hacksaw415 Member
    slum bum frisco
    75 booger green mav
    6x9, fits perfect.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    well I tried making the 6x9's fit but I found that I had to make some cuts into my 71 mav.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    6x9's will fit with minor modifications to the mounting holes. I haven't tried a 6x8 but they might be a perfect fit.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    for the 6x9 I had to make a cut into the metal to widen it and slightly lengthen the pre-existing hole.
  6. Craig Selvey
    I have never had a problem with mounting 6 x 9's in the back. Never had to cut anything. I always mount them under the rear deck. One will have to drill mounting holes.
  7. TUK101
    TUK101 Member
    Elk WA
    Thanks for the help guys. I will probably install a set this weekend.
  8. TUK101
    TUK101 Member
    Elk WA
    Installed a set of 6X9's in the back. It went pretty easy using a dremel to follow the existing holes in the back dash. Not quite as clean as I had hoped, but it could have been worse. I installed an old pair of JVC 6X9's that I had and they dont sound too bad. I am probably going to pick up an amp and a bit better pair soon though, gotta get some boom going.
  9. maverick4925
    maverick4925 Rust, Rust and more Rust
    Amelia, Ohio
    1970 Ford Maverick
    6x9's worked perfect in my 76 maverick. i also put the cones under the metal hooked into the mounting screws, and now they sound even better.
  10. sierra grabber
    sierra grabber Certifiable
    northern nevada
    i mounted my 6X9 up from the bottom instead of down from the top so that their on the mount pad. i was careful to line up the cone though so that even at full extension it shouldnt hit the metal mount. then you dont have to use the factory grill also and can leave the panel on with whatever fancy hole setup you want....
    Dang fast typer beat me to it...hehe
