What thermostat should I use?
Discussion in 'Technical' started by russellgaspard, Sep 9, 2016.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I live in southern louisiana and it stays usually between 85 and 90 degrees here. I'm not really sure what temperature thermostat I should buy.
  2. mojo
    mojo "Everett"- Senior Citizen
    I would say nothing over 180 deg. I use a 180; we get summer temps 80 to 95+ in my area. I think 180, best all around stat for these cars. If the cooling system is not up to par, whatever stat you use, you will have issues.
    Crazy Larry likes this.
  3. russellgaspard
    united states
    So 180 is the best generally?
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    What did the factory use?
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    Probably a 195. But they also corked the motors with 2 bbl carbs and tiny little cockeyed exhaust manifolds too. So obviously power was not the primary concern.
    180 is a good all around temp if you need a little warm air in the eve's and defogger for the early am. Otherwise a 160 will result in a cooler denser intake charge and allows more aggressive tunes if you want that last little bit of power.
  6. lcrabtree
    lcrabtree Member
    Arkansas
    76 Maverick, 95 Mustang, 65 Cobra Replica
    180 works good in NE Arkansas.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
  8. Jett
    Jett Member
    Los Angeles
    1976 Mercury Comet L6 250 ci
    180 in socal with similar all around temperature, since I changed mine to this it never overheated and I just drove from LA to Phoenix and back! By 105° outside
  9. Krazy Comet
    I have a 180* in mine and my other "Hot Rods" as well...
