what tranny?
Discussion in 'Technical' started by inline6, Sep 11, 2004.
  1. inline6
    inline6 Member
    hi everyone,i might of found an auto tranny,but not sure what it is.my wifes uncle has an 84-85 (not sure on the year)mercury marquis station wagon(make one hell of a boat anchor)with a 302.is it possible that the tranny behind it is a c-4 or a c-6?i've heard that both trannys came in that model of wagon,and then i've heard that the c-6 came only in vans and trucks.anyone know for sure?the engine combo is orig.also if it is a c-4 would it be a good tranny to put in the maverick?or would i have to find a different flex plate,torque converter?the motor in the mav is a 73 302 out of a torino.thanks for any help and/or ideas.chuck.
  2. don graham
    from what i understand the c4 was used until 1981, then it was replaced by the c5, so the tranny would probably not be a c4. i don't think a lot of 302's had the c6. some did, but i don't know about the marquis.:) you can go to http://www.mustangcentral.net/tech/c4.html to read up on the c4.
  3. inline6
    inline6 Member
    don,thanks for the link,lot of good info.are the c-5's fairly sturdy,or just not worth it.only problem i could see would be an ecectrical connection for the lockup system.
  4. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    more like its prob a Aod
