Wheel question
Discussion in 'Technical' started by comet 75, Apr 1, 2005.
  1. comet 75
    comet 75 comet 75 swap 302
    Quebec
    mercury comet 1975 302
    does some one can explain me what means all this data that I should take care of when I bought wheel??
    oK rim diameter and width I understand and bolt patern too 5x4.5 or 144,3mm It's what I need.
    1:Now backspacing what it change on the wheel from 3.75 and 4.5???
    2:Beadlock????
    3:conical seat 60 degree????
    4: offset -18mm ?????
    that it's
    here is a example:
    Brand:Eagle Alloys
    Product Line:Eagle Alloys 218 Series Wheels
    Rim Diameter (in):15
    Rim Width (in):8.00
    Backspacing (in):3.75
    Beadlock Functional:No
    Beadlock Included:No
    Rim Material:Spun aluminum
    Center Material:Cast aluminum
    Wheel Finish:polished
    Lug Nut Seat Style:Conical seat
    Wheel Construction:2-piece
    Conical Seat Taper:60 degree
    Hub Centric:No
    Center Cap Included:Yes
    Offset (mm):-18
    Load Rating (lbs):1900
    Valve Stems Included:no
  2. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    ok, a bead lock is what we used in 4wheeling, its a ring that locks the tire to the rim to keep it from popping the bead at low pressure, you don't need it for much anything else other than 4wheeling. The conical taper is the seat for your lug nuts, they should be tapered, not sure what degree. Backspacing determines how far in your tire sits in the wheel well, that is the istance from the wheel mounting surface (wms) IE rotor or drum to the inside edge or bead of your wheel, not sure what the BS is needed for these cars. Offset, I'm not sure what they're asking, I'm sure someone else here can give you a better idea of what you need.
    Shaun
  3. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Back spacing that works well on a Maverick is approx 4" , some can go as much as 4 1/2" but you start getting into clearance issues. Offset is the the amount the center of the wheel is "offset" from the center of the rim. IE a newer car has alot of offset (the face of the wheel is flat) on older car the amount offset is smaller. Causing the the center of the tread of the tire to be closer to the centerline of the rotor/brake drum face(surface) Is that clear as mud?
  4. comet 75
    Quebec
    So if we consider that 0 offset is the middle of the rim -18 offset should be what more inside or more outside from center???. And -18 does it too much for comet ???
