Wheel Size... dose size matter?
Discussion in 'Technical' started by slowcomet, Aug 13, 2003.
  1. slowcomet
    slowcomet Member
    Ca
    1975 Comet
    I am going to put some new wheels and tires on my '75 Comet. I would like to know what size tires you have! and if they rub or cause any other problems.
    Dose anybody run 15" wheels on their Maverick or Comet.
    If you have Torq Thrust D's I would like to see a picture. I am also thinking about Weld drag stars
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    I have 15X7 Torq Thrust Ds on my Maverick. I have 225 60 15s on it. I lower the front a little, so I can't really fit a wider or bigger tire on there without it rubbing. I could put bigger in the back, but then I would lose the ability to rotate them. Here is an old picture , but now that the car is painted it looks really nice with the wheels. Hope this helps you. Where in California are you?
    -Corbin
  3. 75cometgt
    75cometgt Canadain GT
    Wpg. MB. Canada
    75 Comet GT
    I am running 215/70/15 front and 275/60/15 with rear leafs rearched 1 1/2 inches over stock and that combo seem to work great on my car.
  4. slowcomet
    slowcomet Member
    Ca
    1975 Comet
    Corbin, I like your D's I was wondering if a 225 would rub in the front. I am unsure if I will have the same size or a larger tire in the rear...I like the look of fat rear tires. I usually smoke the tires before I can rotate them.
    I am in San Jose
  5. Corbin Johnson
    On my car the 225s don't scrape in the front, but they are very close to the front on the driver's side when I turn all the way to the left. Hope this helps ya out. The Ds are a very nice wheel.
    -Corbin
  6. slowcomet
    slowcomet Member
    Ca
    1975 Comet
    I would like to use 225's or 215's on 7" rims in the front maybe even 205/65-15's for the front and use 225's or 235's for the rear on 8" rims. I will post some pictures of my new wheels in a few days they came from a '72 ford.
  7. slowcomet
    slowcomet Member
    Ca
    1975 Comet
    75cometgt what size wheels do you have in the front?
  8. 75cometgt
    Wpg. MB. Canada
    75 Comet GT
    I am running 215/70/15's on the front they are about 25 inches tall and the 275/60/15 are 29.5 inches tall - the tims are 7's on the front and 8's on the rear. I posted a pic of mine when it was still brown. Still in b/shop getting transformed into the clone of my rusty org GT/.
  9. 75cometgt
    Wpg. MB. Canada
    75 Comet GT
    Sorry forgot to say that thae car in pic is all org paint at the time and 48000 org 302/auto car. My org GT is Orange/Black strip car with this is being turned into.:D
  10. slowcomet
    slowcomet Member
    Ca
    1975 Comet
    75cometgt do you like the fit of your front tires, any problems rubbing? do you like the height?
  11. 75cometgt
    Wpg. MB. Canada
    75 Comet GT
    slow i have no probs with anything rubbing at all and height is just right for the look that im going for. the mid 70 muscle car with smaller tires front big tires rear and rear of car higher then front.
  12. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    75cometgt
    That is one nice looking ride, you have to post a pic after you get it repainted. I like the chrome trim on your tailight panel! :cool:
  13. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Got 15" Magnum 500s 7 inch in front, 8 inch in rear.
    Have 235/60 in front and 255/60 in rear. Need a small spacer in rear as the offset of the wheels is awful close to the leaf. The fronts will rub barely if cranked all the way.
      File size:
      61.3 KB
      251
  14. slowcomet
    slowcomet Member
    Ca
    1975 Comet
    Sweet!! Those Magnum 500 wheels look great. Those are bigger tires than I thought could fit in the wheel well.
  15. Maverick Man
    California
    what rear spacing on the rear magnums do you have?
