wheels
Discussion in 'Technical' started by Bradley M., Feb 27, 2005.
  1. Bradley M.
    Bradley M. Member
    Hawaii
    1970 Ford Maverick
    Does anyone know if a 15x8 with a 4.5 offset will fit on the Maverick? Need to know what size tire can run if son. Wheels is a set of Weld Prostars.:hmmm:
  2. Bradley M.
    Bradley M. Member
    Hawaii
    1970 Ford Maverick
    Forgot to mention the Maverick is a 1970
  3. Mavaholic
    They will rub on your leaf springs unless you space them out some. About 4 1/4 is the most you can go.
  4. igo1090
    igo1090 Member
    catonsville, md
    depending on the section and tread widths of the tire, i dont like to do more than 3.75 backspace, but i'm conservative & dont like to see rub marks on the sidewall.
  5. Bradley M.
    Bradley M. Member
    Hawaii
    1970 Ford Maverick
    What if I add a spacer on the backside of the wheel, would the wheel still stay inside of the fender to a point the rear can be lowered?
  6. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    with 255s of course it would.
  7. Mavaholic
    I'm running 255x15 on mine with 15x8 and 4.4 backspacing. IT fits with no problems. I had my 9" built with an extra 3/16" added to each side. So if you space yours out that amount, they will fit.
  8. Bradley M.
    Bradley M. Member
    Hawaii
    1970 Ford Maverick
    thanks for all the help, Can't wait to put on the Prostar wheels.:bananaman
    Honda's In Hawaii BEWARE........:evilsmile I AM COMMING TO PLAAAAAAAAAYYYYYYYYYY
    Aloha Everyone..
  9. tommyboy
    tommyboy 77 mav
    parkersburg west virginia
    1977 maverick
    hey guys ive heard u talk about spaceing your wheels and just how do u do that?
  10. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Backspacing is the measurment from the outside of the brake drum, ( where the wheel meets the drum) inwards towards the leaf springs ( speaking in rear terms). So a 4" backspacing would be just that. From what I know on a magnum 500 wheel the factory backspacing and the guide the tire and wheels stores go by gives a stock backspacing of 4".
    Dan
